1.3CDTI 16v
1.3CDTI 16V Engine Specification
Motor Özellikleri Engine, location: Front, transverse in front of axle, 12" inclined
Motor, yeri: Açık, aks önünde çapraz, 12 "eğimli Cooling system: Liquid, sealed circuit
Soğutma sistemi: Sıvı, imzalanan devre Cylinders, number: 4
Silindir, sayı: 4 Bore (mm) 69.6
Çap (mm) 69,6 S troke (mm): 82
S troke (mm): 82 Displacement (cc): 1248
Deplasman (cc): 1248 Compression ratio: 18: 01
Sıkıştırma oranı: 18: 01 Engine, type: In line; 5 main bearings
Motor yazın: doğrultusunda; 5 ana yataklar Cylinder block/ head, material: Cast iron/ aluminium alloy
Silindir engelleme başkanı malzemesi: Dökme demir / alüminyum alaşım Camshaft (s), location: 2 overhead (DOHC), driven by chain
Camshaft (ler), yeri: 2 havai (DOHC), zincir ile tahrik Valve train: Indirect roller cam followers, hydraulic tappets
Vana tren: Dolaylı silindir kam takipçisi, hidrolik tappets Valve, arrangement: Parallel; 4 per cylinder
Vana, düzenleme: Paralel; 4 silindir başına Valve, adjustment: Automatic - hydraulic
Vana, ayarı: Otomatik - Hidrolik Fuel system: Diesel direct injection, common rail
Yakıt sistemi: Dizel doğrudan enjeksiyon, Common Rail Ignition system: n/a
Ateşleme sistemi: n / a Fuel pump: Mechanical
Yakıt pompası: Mekanik Emission control system: 2 - way cat.
Emisyon kontrol sistemi: 2 - yolu cat. conv., exhaust gas recirculation
Dönş. egzoz gaz recirculation Output (kW/hp CEE at 1/min): 66/ 90 at 4000
Çıkış (kW / 1/min at HP C harfi): 66 / 90 4000 at Specific power (kW/l; hp/l): 52.9; 72.1
Özel gücü (kW / l; kW / l): 52,9, 72,1 Max.
Maks. torque (Nm at 1/ min): 200 at 1750-2500
Tork (Nm 1 / dak at): 200 1750-2500 at Specific torque (Nm/litre): 160.3
Özel tork (Nm / lt): 160,3 Mean effective pressure at max.
Maksimum etkili basınç Mean. power/ max.
güç / max. torque (kPa): 1586.5/ 2014.7
tork (kPa): 1586,5 / 2014,7 Average piston speed (m/ s): 10.9
Piston ortalama hızı (m / s): 10.9 Engine oil, capacity (l): 3.5
Motor yağı, kapasite (l): 3,5 Cooling capacity (l): 5.6
Soğutma kapasitesi (l): 5,6 Battery 12 V,
Pil 12 V, Capacity (Ah): 60
Kapasite (Ah): 60 Alternator 14.2 V,
Alternatör 14,2 V, Capacity (W): 994
Kapasitesi (W): 994 Max.
Maks. service interval: 20,000 miles or 1 year
servis aralığı: 20.000 km veya 1 yıl Emission compliance: Euro 4 Engine mass (kg): 134.1
Emisyon uyum: Euro 4 Motor kitle (kg): 134,1 Charger system: Turbo with intercooler
Şarj sistemi: Turbo Intercooler ile Max.
Maks. boost pressure (bar): tba
artırmak basıncı (bar): TBA Power Output (kW) Torque (Nm)
Güç Çıkışı (kW) Tork (Nm)
