Tum GM otomobiller icin gecerli en kapsamlı hata kodu listesi
  • Konuyu Başlatan Konuyu Başlatan weSti555
weSti555
21 Ağu 2006
Manufature codes
  • DTC 01 - General Sensor Fault
  • DTC 02 - Instantaneous Battery Voltage Out of Range
  • DTC 03 - Filtered Battery Voltage Out of Range
  • DTC 04 - Compressor Relay Short to Ground/Open
  • DTC 05 - Compressor Relay Short to Battery
  • DTC 06 - Exhaust Valve Short to Ground/Open Circuit
  • DTC 07 - Exhaust Valve Short to Battery
  • DTC 08 - Warning Lamp Short to Ground/Open Circuit
  • DTC 09 - Warning Lamp Short to Battery
  • DTC 10 - Inside Air Temperature Sensor Voltage Low
  • DTC 10 - Intake Accumulator Fault
  • DTC 11 - Driver Seat Forward/Backward Motor Inop
  • DTC 11 - Exhaust Accumulator Fault
  • DTC 11 - Inside Air Temperature Sensor Open Circuit
  • DTC 11 - Transponder Key Problem
  • DTC 12 - Consecutive Intake Malfunction
  • DTC 12 - Driver Seat Recliner Motor Inoperative
  • DTC 12 - LH Air Outlet Sensor Voltage Low
  • DTC 12 - Wrong Transponder Key
  • DTC 12 - Diagnostic System Check (Escalade)
  • DTC 13 - Driver Air Bag Deployment Loop Short to GND
  • DTC 13 - Immobilizer Not Programmed
  • DTC 13 - LH Air Outlet Sensor Open Circuit
  • DTC 14 - Coolant Temp Voltage Low
  • DTC 14 - Driver Pretens Deployment Loop Short to GND
  • DTC 14 - No Transponder Key Programmed
  • DTC 14 - RH Air Outlet Sensor Voltage Low
  • DTC 15 - Driver Air Bag Deploy. Loop Short to V
  • DTC 15 - RH Air Outlet Sensor Open Circuit
  • DTC 15 - Vehicle Speed Signal Voltage Low
  • DTC 16 - Driver Pretens Deploy Loop Short to Voltage
  • DTC 16 - Driver Seat Front Height Motor Inoperative
  • DTC 16 - Int Air Mix Door Mtr Volts Low/Open Circuit
  • DTC 16 - Vehicle Speed Signal Voltage High
  • DTC 17 - Driver Seat Rear Height Motor Inoperative
  • DTC 17 - Interior Air Mix Door Motor Voltage High
  • DTC 17 - No Engine Request Received
  • DTC 18 - Driver Side Mirror Circuit
  • DTC 18 - LH Air Mix Door Mtr Volts Low/Open Circuit
  • DTC 18 - MIL Circuit
  • DTC 19 - Inside Mirror Circuit
  • DTC 19 - LH Air Mix Door Motor Voltage High
  • DTC 20 - Passenger Side Mirror Circuit
  • DTC 20 - RH Air Mix Door Mtr Volts Low/Open Circuit
  • DTC 21 - Driver Seat Adjuster Switch Inoperative
  • DTC 21 - No Speed Signal
  • DTC 21 - RH Air Mix Door Motor Voltage High
  • DTC 21/31 - Courtesy Lamps Feed Shorted to Ground (Escalade)
  • DTC 22 - Floor Air Mix Dr Mtr Voltage Low/Open Circuit
  • DTC 22 - Solenoid Circuit Short to Ground/Open
  • DTC 22/32 - Courtesy Lamps Return Shorted to Battery (Escalade)
  • DTC 23 - Floor Air Mix Door Motor Voltage High
  • DTC 23 - Passenger Air Bag Deployment Loop Short to GND
  • DTC 23 - Power Steering Control Module Malfunction
  • DTC 23/33 - RAP Feed Shorted to Ground or Battery (Escalade)
  • DTC 24 - Def Air Mix Door Mtr Volts Low/Open Circuit
  • DTC 24 - Passenger Pretens Deployment Loop Short to GND
  • DTC 24/34 - Seatbelt Indicator Shorted to Ground or Battery (Escalade)
  • DTC 25 - Defrost Air Mix Door Motor Voltage High
  • DTC 25 - Passenger Air Bag Deploy. Loop Short to Voltage
  • DTC 25/35 - Security Indicator Status (Escalade)
  • DTC 26 - Passenger Pretens Deploy. Loop Short to Voltage
  • DTC 27 - Blower Motor Voltage Low or Open Circuit
  • DTC 28 - Air Circ. Valve Voltage Low or Open Circuit
  • DTC 29 - Air Circulation Valve Voltage High
  • DTC 30 - Heating Cut-Off Valve Volts Low or Open Circuit
  • DTC 31 - Driver Air Bag Deploy. Loop Resistance High
  • DTC 31 - Heating Cut-Off Valve Voltage High
  • DTC 32 - Driver Air Bag Deploy. Loop Resistance Low
  • DTC 32 - Rear Window Defog Signal Voltage Low
  • DTC 33 - Passenger Air Bag Deploy. Loop Resistance High
  • DTC 33 - Rear Window Defog Signal Voltage Open Circuit
  • DTC 34 - Passenger Air Bag Deploy. Loop Resistance Low
  • DTC 34 - Rear Window Defogger Open Circuit
  • DTC 35 - A/C Request Signal Voltage High
  • DTC 35 - Driver Pretens Deploy. Loop Resistance High
  • DTC 36 - A/C Request Signal Voltage Low
  • DTC 36 - Driver Pretens Deploy. Loop Resistance Low
  • DTC 37 - Heater and A/C Control Switch Stuck
  • DTC 37 - Passenger Pretens Deploy. Loop Resistance High
  • DTC 38 - Passenger Pretens Deploy. Loop Resistance Low
  • DTC 38 - Solar/Twilight Sensor Supply Voltage Low
  • DTC 39 - Solar/Twilight Sensor Supply Voltage High
  • DTC 40 - Solar/Twilight Sensor GND Short to Voltage
  • DTC 41 - Last Message Received Valid (Escalade)
  • DTC 42 - Last Message Received Invalid (Escalade)
  • DTC 43 - Last Message Received with Sumcheck Error (Escalade)
  • DTC 43 - Warning Lamp Circuit Short to Voltage
  • DTC 44 - Warning Lamp Circuit Open or Short to GND
  • DTC 44 - Last Message Received with Encryption Error (Escalade)
  • DTC 45 - Receiver Processing in 20 Second Lockout (Escalade)
  • DTC 50 - Seat Adjuster Memory Module Malfunction
  • DTC 50, 51, or 55 - Sunroof Actuator Malfunction
  • DTC 51 - Replace Heater and A/C Control
  • DTC 51 - Reprogram Cluster or Cluster Malfunction
  • DTC 52 - Heater and A/C Control Not Programmed
  • DTC 52 - Reprogram Cluster
  • DTC 52 - SDM Not Configured
  • DTC 53 - Configuration Mismatch
  • DTC 55 - Internal SDM Failure
  • DTC 55 - Replace Heater and A/C Control
  • DTC 55 - Seat Adjuster Memory Module Malfunction
  • DTC 55 - Theft Deterrent Module Malfunction
  • DTC 55 - Begin Configuration Display (Escalade)
  • DTC 56 - SDM Not Reusable
  • DTC 65 - Passenger Air Bag Deployment Commanded
  • DTC 66 - Driver Air Bag Deployment Commanded
  • DTC 67 - Pretensioner Only Deployment Commanded
  • DTC 68 - Driver Side Air Bag Deployment Commanded
  • DTC 69 - Passenger Side Air Bag Deployment Commanded
  • DTC 71 - Driver Side Impact Sensor Comms Invalid
  • DTC 73 - Driver Side Impact Sensor Short to Voltage
  • DTC 74 - Driver Side Impact Sensor Short to Ground
  • DTC 75 - Driver Side Air Bag Short to Ground
  • DTC 76 - Driver Side Air Bag Short to Voltage
  • DTC 77 - Driver Side Air Bag Deploy Loop Resist High
  • DTC 78 - Driver Side Air Bag Deploy Loop Resist. Low
  • DTC 81 - Passenger Side Impact Sensor Comms Invalid
  • DTC 83 - Passenger Side Impact Sensor Short to Voltage
  • DTC 84 - Passenger Side Impact Sensor Short to Ground
  • DTC 85 - Passenger Side Air Bag Short to Ground
  • DTC 86 - Passenger Side Air Bag Short to Voltage
  • DTC 87 - Passenger Side Air Bag Deploy. Loop Resist High
  • DTC 88 - Passenger Side Air Bag Deploy. Loop Resist. Low
  • DTC 97 - ONSTAR DCO Link Open or Short to Voltage
  • DTC 98 - ONSTAR DCO Link Short to Ground
  • DTC 167 - Fuel Gauge Voltage Low
  • DTC 168 - Fuel Gauge Voltage High
  • DTC 169 - Outside Temperature Sensor Voltage Low
  • DTC 171 - Outside Temperature Sensor Open Circuit
Body codes
  • B0001 - PCM Discrete Input Speed Signal Error
  • B0004 - PCM Discrete Input Speed Signal Not Present
  • B0005 - In Park Switch Circuit Malfunction
  • B0012 - Right Front/Passenger Frontal Deployment Loop Circuit
  • B0013 - Right Front/Passenger Frontal Deployment Loop Circuit
  • B0014 - Right Front/Passenger Frontal Deployment Loop Circuit
  • B0016 - Right Front/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low
  • B0017 - Right Front/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Open
  • B0018 - Right Front/Passenger Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range
  • B0022 - Left Front/Driver Frontal Deployment Loop (Single Stage or Stage 1) Resistance Low
  • B0024 - Left Front/Driver Frontal Deployment Loop (Single Stage or Stage 1) Short to Ground/Voltage Out of Range
  • B0026 - Left Front/Driver Frontal Deployment Loop (Single Stage or Stage 1) Open
  • B0028 - Right Front/Passenger Side Deployment Loop Resistance Low
  • B0029 - Right Front/Passenger Side Deployment Loop Open
  • B0030 - Right Front/Passenger Side Deployment Loop Short to Ground/Voltage Out of Range
  • B0035 - ADS Closed/Shorted to Ground
  • B0036 - ADS Open/Missing/Shorted to Battery
  • B0037 - AUX switch closed/shorted to ground
  • B0038 - AUX switch open/shorted to battery
  • B0040 - Left Front/Driver Side Deployment Loop Resistance Low
  • B0041 - Left Front/Driver Side Deployment Loop Open
  • B0042 - Left Front/Driver Frontal Deployment Loop Circuit
  • B0043 - Left Front/Driver Frontal Deployment Loop Circuit
  • B0044 - Left Front/Driver Frontal Deployment Loop Circuit
  • B0045 - Left Front Side Deploy Loop Short to Ground/Voltage Out of Range
  • B0051 - Deployment Commanded
  • B0053 - Deployment Commanded with Loop Malfunctions Present
  • B0057 - Right Front/Passenger Pretensioner Deployment Loop Resistance Low
  • B0058 - Right Front/Passenger Pretensioner Deployment Loop Open
  • B0059 - Right Front/Passenger Pretensioner Deployment Loop Short to Ground/Voltage Out of Range
  • B0061 - Roof Rail Module-Left Deployment Loop Circuit
  • B0062 - Roof Rail Module-Left Deployment Loop Circuit
  • B0064 - Left Front/Driver Pretensioner Deployment Loop Resistance Low
  • B0065 - Left Front/Driver Pretensioner Deployment Loop Open
  • B0066 - Left Front/Driver Pretensioner Deployment Loop Short to Ground/Voltage Out of Range
  • B0068 - Roof Rail Module-Left Deployment Loop Circuit
  • B0069 - Roof Rail Module-Right Deployment Loop Circuit
  • B0070 - Roof Rail Module-Right Deployment Loop Circuit
  • B0071 - Roof Rail Module-Right Deployment Loop Circuit
  • B0073 - Supplemental Deployment Loop #1 Resistance Low
  • B0074 - Supplemental Deployment Loop #1 Open
  • B0075 - Supplemental Deployment Loop #1 Short to Ground/Voltage Out of Range
  • B0077 - Left Front/Driver Side Impact Sensor (SIS) Malfunction
  • B0078 - Right Front/Passenger SIS Malfunction
  • B0079 - Incorrect Left Front/Driver SIS Installed
  • B0080 - Discard Left Front/Driver SIS
  • B0081 - Incorrect Right Front/Passenger SIS Installed
  • B0082 - Discard Right Front/Passenger SIS
  • B0086 - Supplemental Deployment Loop #2 Resistance Low
  • B0087 - Supplemental Deployment Loop #2 Open
  • B0088 - Supplemental Deployment Loop #2 Short to Ground/Voltage Out of Range
  • B0090 - Active switch voltage out of range
  • B0091 - Active switch: wrong state
  • B0092 - PPS passenger detection error
  • B0093 - PPS/CPS self-test malfunction
  • B0094 - CPS childseat detection error
  • B0095 - SDM-PPS/CPS mismatch malfunction
  • B0100 - Electronic Front End Sensor 1 Performance
  • B0101 - Electronic Front End Sensor 1 Performance
  • B0102 - Electronic Front End Sensor 1 Performance
  • B0103 - Electronic Frontal Sensor Circuit
  • B0104 - Electronic Frontal Sensor Circuit
  • B0105 - Electronic Frontal Sensor Circuit
  • B0109 - Side impact module-Left Rear deployment loop resistance is less than 1.3 ohms
  • B0110 - Side impact module-Left Rear high circuit is less than 2.4 volts
  • B0111 - Side impact module-Left Rear high and/or low circuits is short to ground or short to voltage
  • B0112 - Side impact module-Right Rear deployment loop resistance is less than 1.3 ohms
  • B0113 - Side impact module-Right Rear high circuit is less than 2.4 volts
  • B0114 - Side impact module-Right Rear high and/or low circuits is short to ground or short to voltage
  • B0126 - Right Panel Discharge Temperature Fault
  • B0130 - Air Temperature/Mode Door Actuator Malfunction
  • B0131 - Right Heater Discharge Temperature Fault
  • B0145 - Auxiliary HAVC Actuator Circuit
  • B0159 - Outside Air Temperature Sensor Circuit Range/Performance
  • B0160 - Ambient Air Temperature Sensor Circuit
  • B0162 - Ambient Air Temperature Sensor Circuit
  • B0164 - Passenger Compartment Temperature Sensor #1 (Single Sensor or LH) Circuit Range/Performance
  • B0169 - In-car Temp Sensor Failure (passenger -not used)
  • B0174 - Output Air Temperature Sensor #1 (Upper; Single or LH) Circuit Range/Performance
  • B0179 - Output Air Temperature Sensor #2 (Lower; Single or LH) Circuit Range/Performance
  • B0183 - Sunload Sensor Circuit
  • B0184 - Solar Load Sensor #1 Circuit Range (sunload)
  • B0188 - Sunload Sensor Circuit
  • B0189 - Solar Load Sensor #2 Circuit Range (sunload)
  • B0229 - HVAC Actuator Circuit
  • B0248 - Mode Door Inoperative Error
  • B0249 - Heater/Defrost/AC Door Range Error
  • B0263 - HVAC Actuator Circuit
  • B0268 - A/I Door Inoperative Error
  • B0269 - Air Inlet Door Range Error
  • B0283 - Electric Rear Defrost Circuit
  • B0285 - Electric Rear Defrost Circuit Low (BCM)
  • B0286 - Electric Rear Defrost Circuit High (BCM)
  • B0408 - Temperature Control #1 (Main/Front) Circuit Malfunction
  • B0409 - Air Mix Door #1 Range Error
  • B0414 - Air Temperature/Mode Door Actuator Malfunction
  • B0418 - HVAC Actuator Circuit
  • B0419 - Air Mix Door #2 Range Error
  • B0423 - Air Mix Door #2 Inoperative Error
  • B0424 - Air Temperature/Mode Door Actuator Malfunction
  • B0428 - Air Mix Door #3 Inoperative Error
  • B0429 - Temperature Control #3 Rear Circuit Range/Performance
  • B0510 - RH Panel Discharge Temp Sensor Failure
  • B0515 - RH Heater Discharge Temp Sensor Failure
  • B0520 - Rear Discharge Temp Sensor Failure
  • B0530 - Fuel Level Sensor Stuck
  • B0532 - Fuel Sensor Shorted To Ground
  • B0533 - Fuel Sensor Open/Shorted To B+
  • B0540 - Speedometer Circuit
  • B0560 - Tachometer Circuit
  • B0688 - Security System Indicator Circuit High
  • B0689 - Security System Indicator Circuit Open (BCM)
  • B0728 - P (park) Indicator Circuit High (BCM)
  • B0729 - P (park) Indicator Circuit Open (BCM)
  • B0733 - R (reverse) Indicator Circuit High (BCM)
  • B0734 - R (reverse) Indicator Circuit Open (BCM)
  • B0738 - N (neutral) Indicator Circuit High (BCM)
  • B0739 - N (neutral) Indicator Circuit Open (BCM)
  • B0748 - D (drive) Indicator Circuit High (BCM)
  • B0749 - D (drive) Indicator Circuit Open (BCM)
  • B0768 - Service Indicator Circuit High
  • B0770 - All Wheel Drive (AWD) Indicator Circuit
  • B0775 - Four Wheel Drive High Range (4HI) Indicator Circuit
  • B0780 - Four Wheel Drive Low Range (4LO) Indicator Circuit
  • B0785 - Two Wheel Drive High Range (2HI) Indicator Circuit
  • B0790 - Transfer Case Neutral Indicator Circuit
  • B0846 - +5 Volt Reference Out of Range
  • B0856 - Battery 2 Out of Range
  • B0951 - Dimming Circuit
  • B1000 - ECU Malfunction
  • B1001 - Option Configuration Error
  • B1004 - Keep Alive Memory (KAM)
  • B1008 - Calibration Data Not Programmed (BCM)
  • B1007 - EEPROM Write Error
  • B1009 - EEPROM Checksum Error
  • B1013 - ROM Checksum Error
  • B1014 - Program ROM Checksum Error
  • B1015 - Passenger Deploy. Loop Resistance High
  • B1016 - Passenger Deployment Loop Resistance Low
  • B1017 - Passenger Deployment Loop Open
  • B1018 - Passenger Deployment Loop Short to GND
  • B1019 - Passenger Deploy. Loop Short to Voltage
  • B1021 - Driver Deployment Loop Resistance High
  • B1022 - Driver Deployment Loop Resistance Low
  • B1023 - Integral Switch Performance
  • B1024 - Driver Deployment Loop Short to Ground
  • B1025 - Driver Deployment Loop Short to Voltage
  • B1026 - Driver Deployment Loop Open
  • B1035 - Discr. Sensor Closed or Short to GND
  • B1036 - Discr. Sensor Open or Short to Voltage
  • B1045 - Audio Output 3 Circuit (Radio)
  • B1051 - Frontal Air Bag and Preten Deployment
  • B1053 - Deployment Commanded w/Loop Malfunction
  • B1054 - Infl Rst IP Module Switch Circuit Failure
  • B1055 - Audio Output 4 Circuit (Radio)
  • B1061 - Lamp Circuit Failure
  • B1071 - Internal SDM Failure
  • B1115 - Passenger Deploy. Loop Resistance High
  • B1116 - Passenger Deploy. Loop Resistance Low
  • B1117 - Passenger Deployment Loop Open
  • B1121 - Driver Deployment Loop Resistance High
  • B1122 - Driver Deployment Loop Resistance Low
  • B1124 - Driver/Passenger Deploy. Loop Short to GND
  • B1125 - Driver/Pass Deploy Loop Short to Voltage
  • B1126 - Driver Deployment Loop Open
  • B1131 - Passenger Pretensioner Loop Resistance High
  • B1132 - Passenger Pretensioner Loop Resistance Low
  • B1134 - Passenger Pretensioner Loop Open
  • B1135 - Discr. Sensor Closed or Short to GND
  • B1136 - Discr. Sensor Open or Short to Voltage
  • B1141 - Driver Pretensioner Loop Resistance High
  • B1142 - Driver Pretens. Deploy. Loop Res. Low
  • B1144 - Driver/Pass Pretens. Loop Short to GND
  • B1145 - Driver/Pass Pretens. Loop Short to Volt
  • B1146 - Driver Pretensioner Loop Open
  • B1147 - Driver Side Air Bag System Malfunction
  • B1148 - Passenger Side Air Bag System Malfunction
  • B1151 - Deployment Commanded - Frontal
  • B1152 - Data Area Full
  • B1153 - Deployment Commanded w/Loop Malfunction
  • B1155 - SDM Calibration Mismatch
  • B1159 - Loss of Serial Data-Key Not Received
  • B1160 - Loss of Serial Data - VIN Not Received
  • B1161 - Lamp Circuit Failure
  • B1163 - Loss of Serial Data-No Lamp Response
  • B1171 - Internal SDM Failure
  • B1245 - CD Changer Not Responding
  • B1259 - The digital radio receiver detects an antenna fault
  • B1271 - Theft Lock Enabled - VIN does not match expect value
  • B1310 - Ambient Air Temperature Sensor Failure
  • B1311 - Outside Air Temp Sensor Short Circuit
  • B1312 - High Side Temp Sensor Open Circuit
  • B1313 - High Side Temp Sensor Short Circuit
  • B1314 - Evaporator Inlet Temp Sensor Open Circuit
  • B1315 - Evaporator Inlet Temp Sensor Short Circuit
  • B1316 - In Car Temperature Sensor Open Circuit
  • B1317 - In Car Air Temperature Sensor
  • B1318 - LH Sun Load Sensor Fault
  • B1319 - Sunload Sensor Short Circuit
  • B1321 - A/C Low Side Temperature Sensor Fault
  • B1324 - A/C Refrigerant Overpressure
  • B1327 - Vehicle system voltage below 9.0 volts
  • B1328 - Vehicle system voltage is greater than 15.9 volts
  • B1328 - RH Sun Load Sensor Fault
  • B1330 - Left A/C Discharge Sensor Fault
  • B1331 - Right A/C Discharge Sensor Fault
  • B1332 - Left Heater Discharge Sensor Fault
  • B1333 - Right Heater Discharge Sensor Fault
  • B1336 - Memory seat module (MSM) current exceeds 81 amps
  • B1340 - Air Mix Door One Movement Fault
  • B1341 - Air Mix Door Two Movement Fault
  • B1343 - Air Inlet Door Movement Fault
  • B1344 - HeaterDefrost/AC Door Movement Fault
  • B1347 - Very Low A/C Refrigerant Warning
  • B1348 - Very Low A/C Refrigerant Pressure
  • B1350 - Engine Coolant Over-Temperature
  • B1372 - Device Ignition 1 Circuit Low
  • B1375 - Device Ignition 3 (ON) Circuit
  • B1377 - Device Ignition 3 (ON) Circuit Low (BCM)
  • B1378 - Device Ignition 3 (ON) Circuit High (BCM)
  • B1382 - Device Ignition ACCESSORY Circuit Low
  • B1390 - Device Voltage Reference Input Circuit Malfunction
  • B1396 - Device Voltage Reference Output 1 Circuit Range Performance
  • B1399 - Loss of KDD Communications
  • B1420 - Seat Switch Input Status
  • B1422 - Device Power Moding Malfunction
  • B1438 - IPC High Voltage Output Overcurrent to IPM
  • B1440 - Power Mode Master Input Circuits Mismatch
  • B1480 - Battery Rundown Protection Circuit Malfunction
  • B1482 - Battery Rundown Protection Circuit Low (BCM)
  • B1513 - Voltage falls below 10.5 volts with the engine is running
  • B1514 - Voltage is greater than 16.2 volts with the engine running
  • B1550 - Mirror Left Front or Right Front Select Switch Circuit
  • B1552 - Keep Alive Memory (KAM) Error
  • B1556 - IPC EEPROM Odo/Configuration Error
  • B1557 - EEPROM Calibration Error
  • B1558 - BCM EPROM Checksum Error
  • B1586 - Mirror Horiz. Pos Sensor-Out of Range/Open
  • B1591 - Mirror Vert. Pos Sensor-Out of Range/Open
  • B1652 - Loss of Keep Alive Memory (KAM)
  • B1656 - EEPROM Write Error
  • B1658 - EEPROM Checksum Error
  • B1697 - Mirror Switch L Input Shorted to Ground
  • B1698 - Mirror Switch L Up Input Stuck High
  • B1702 - Mirror Switch L Input Shorted to Ground
  • B1703 - Mirror Switch L Down Input Stuck High
  • B1707 - Mirror Switch R Input Shorted to Ground
  • B1708 - Mirror Switch R Up Input Stuck High
  • B1710 - Switched Antenna Error
  • B1712 - Mirror Switch R Input Shorted to Ground
  • B1713 - Mirror Switch R Down Input Stuck High
  • B1717 - Mirror Power Fold Control Switch Shorted Low
  • B1718 - Power Folding Mirror Switch Input Circuit High
  • B1720 - Mirror Up and Down Control Switch Circuit
  • B1721 - Mirror Left and Right Control Switch Circuit
  • B1723 - Mirror Motor Control Circuit 1 Performance
  • B1724 - Mirror Motor Control Circuit 2 Performance
  • B1735 - Driver Seat Front Up Switch Circuit Malfunction (Power Seat Switch Circuit)
  • B1740 - Driver Seat Front Down Switch Circuit Malfunction
  • B1745 - Driver Seat Rear Up Switch Circuit Malfunction
  • B1750 - Driver Seat Rear Down Switch Circuit Malfunction
  • B1755 - Driver Seat Asm Forward Switch Circuit Malfunction
  • B1760 - Driver Seat Asm Rearward Switch Circuit Malfunction
  • B1760 - CD Changer Not Responding
  • B1761 - CD changer tracking fault
  • B1762 - CD changer focus error
  • B1763 - CD player load/unload fault
  • B1770 - Cassette not responding
  • B1771 - Cassette tape slow
  • B1772 - Cassette head cleaning required
  • B1780 - Theft Lock Enabled
  • B1802 - Inadv. Pwr Short to Ground
  • B1805 - Ignition Switch Problem
  • B1815 - Driver Recline Forward Switch Circuit Malfunction
  • B1820 - Driver Recline Rearward Switch Circuit Malfunction
  • B1825 - Driver Recline Sensor Circuit Malfunction
  • B1830 - Driver Lumbar Forward Switch Circuit Malfunction
  • B1835 - Driver Lumbar Rearward Switch Circuit Malfunction
  • B1840 - Driver Lumbar Up Switch Circuit Malfunction
  • B1845 - Driver Lumbar Down Switch Circuit Malfunction
  • B1850 - Driver Lumbar Horiz Sensor Circuit Malfunction
  • B1860 - Driver Lumbar Vert Sensor Circuit Malfunction
  • B1870 - Driver Belt Tower Up Switch Circuit Malfunction
  • B1875 - Driver Belt Tower Down Switch Circuit Malfunction
  • B1900 - Driver Belt Tower Vert Sensor Circuit Malfunction
  • B1910 - Generator L-Terminal Open Circuit
  • B1911 - Generator L-Terminal Problem
  • B1913 - Heated Seat Switch - Mode Input Shorted to Battery
  • B1918 - Heated Seat Switch - Temperature Input Shorted to Battery
  • B1970 - Exterior Lamp Power
  • B1971 - Inadvertent Power
  • B1972 - Low Power Driver Fault
  • B1973 - High Power Control Fault
  • B1981 - Battery Voltage Low
  • B1982 - Device Power Circuit High
  • B1983 - Device Power Circuit Low
  • B2075 - Lumbar Switch Control Circuit
  • B2080 - Lumbar Switch Control Circuit
  • B2085 - Lumbar Switch Control Circuit
  • B2090 - Lumbar Switch Control Circuit
  • B2101 - Recline Aft Switch Failed
  • B2102 - Recline Forward Switch Failed
  • B2103 - Rear Vertical Down Switch Failed
  • B2104 - Rear Vertical Up Switch Failed
  • B2105 - Horizontal Aft Switch Failed
  • B2106 - Horizontal Forward Switch Failed
  • B2107 - Front Vertical Down Switch Failed
  • B2108 - Front Vertical Up Switch Failed
  • B2109 - Lumbar Aft Switch Failed
  • B2110 - Lumbar Forward Switch Failed
  • B2111 - Lumbar Down Switch Failed
  • B2112 - Lumbar Up Switch Failed
  • B2115 - Recline Sensor Failed
  • B2116 - Rear Vertical Sensor Failed
  • B2117 - Horizontal Sensor Failed
  • B2118 - Front Vertical Sensor Failed
  • B2119 - Lumbar Forward/Aft Sensor Failed
  • B2120 - Lumbar Up/Down Sensor Failed
  • B2130 - Driver Memory 1 Select Switch Circuit Malfunction
  • B2131 - Driver Memory 2 Select Switch Circuit Malfunction
  • B2132 - Driver Memory Exit Exit/Off Switch Circuit Malfunction
  • B2133 - Driver Memory Set Switch Circuit Malfunction
  • B2140 - Mirror Up Control Switch Circuit Malfunction
  • B2141 - Mirror Down Control Switch Circuit Malfunction
  • B2142 - Mirror Left Control Switch Circuit Malfunction
  • B2143 - Mirror Right Control Switch Circuit Malfunction
  • B2144 - Left Front Mirror Vertical Position Sensor Circuit Low
  • B2145 - Left Front Mirror Vertical Position Sensor Circuit High
  • B2146 - Left Front Mirror Horizontal Position Sensor Circuit Low
  • B2147 - Left Front Mirror Horizontal Position Sensor Circuit High
  • B2148 - Right Front Mirror Vertical Position Sensor Circuit Low
  • B2149 - Right Front Mirror Vertical Position Sensor Circuit High
  • B2150 - Right Front Mirror Horizontal Position Sensor Circuit Low
  • B2151 - Right Front Mirror Horizontal Position Sensor Circuit High
  • B2175 - Tilt/Telescope Module Manual Switch Fail
  • B2200 - Left Front Window Switch Stuck in Up Position
  • B2201 - Left Front Window Switch Stuck in Down Position
  • B2202 - Right Front Window Switch Stuck in Up Position
  • B2203 - Right Front Window Switch Stuck in Down Position
  • B2204 - Left Rear Window Switch Stuck in Up Position
  • B2205 - Left Rear Window Switch Stuck in Down Position
  • B2206 - Right Rear Window Switch Stuck in Up Position
  • B2207 - Right Rear Window Switch Stuck in Down Position
  • B2212 - Right Front Switch on Left Front Door Stuck Up Position
  • B2213 - Right Front Switch on Left Front Door Stuck Down Position
  • B2214 - Left Rear Switch on Left Front Door Stuck Up Position
  • B2215 - Left Rear Switch on Left Front Door Stuck Down Position
  • B2216 - Right Rear Switch on Left Front Door Stuck Up Position
  • B2217 - Right Rear Switch on Left Front Door Stuck Down Position
  • B2220 - Left Front Door Lock/Unlock Switch Stuck in Lock
  • B2221 - Left Front Door Lock/Unlock Switch Stuck UnLock
  • B2222 - Right Front Door Lock/Unlock Switch Stuck in Lock
  • B2223 - Right Front Door Lock/Unlock Switch Stuck UnLock
  • B2224 - Left Rear Door Lock/Unlock Switch Stuck in Lock
  • B2226 - Right Rear Door Lock/Unlock Switch Stuck in Lock
  • B2240 - Memory 1 Switch Failed
  • B2241 - Memory 2 Switch Failed
  • B2242 - Memory Exit Switch Failed
  • B2243 - Memory Set Switch Failed
  • B2310 - Hand Set Failure
  • B2311 - TRU Failure
  • B2312 - Software Failure
  • B2355 - Driver Front Vertical Sensor Malfunction
  • B2365 - Driver Rear Vertical Sensor Malfunction
  • B2375 - Driver Seat Asm Horiz Sensor Circuit Malfunction
  • B2419 - Twilight Photocell Circuit Problem
  • B2420 - Twilight Delay Pot Failure
  • B2422 - Interior Lamp Rheostat Failure
  • B2425 - Seat Heater Circuit
  • B2430 - Seat Heater Circuit
  • B2435 - Seat Back Heater Sensor
  • B2440 - Seat Back Heater Sensor
  • B2455 - Open or short in Cellular Phone Microphone Circuit
  • B2460 - Navigation Antenna Selector Circuit High Current
  • B2461 - Navigation ECU Synchronous Signal Error
  • B2462 - GPS Signal Error
  • B2463 - Navigation CD Player - No Disk
  • B2464 - Navigation CD Player - Decoding Error
  • B2465 - Navigation CD Player - Data Error
  • B2466 - Navigation VICS Memory Error
  • B2468 - Navigation Display Head (NDH) Malfunction
  • B2470 - Daytime Running Lamps Fault
  • B2470 - Cellular Phone Antenna Circuit (2000+)
  • B2471 - Interior Lamp Fault
  • B2472 - Low Beam Fault
  • B2473 - High Beam Fault
  • B2474 - Navigation Display Head (NDH) Back Lighting Malfunction
  • B2475 - Navigation Display Head (NDH) Auxiliary Input Malfunction
  • B2476 - Cellular Phone Select Service Switch Malfunction (keypad signal circuit)
  • B2477 - Reverse Lamp Relay Shorted to Ground
  • B2478 - Reverse Lamp Shorted to Battery
  • B2482 - Cellular Phone Select Service Switch Range/Performance
  • B2483 - Global Positioning System (GPS) Antenna Circuit
  • B2484 - Global Positioning System (GPS) Antenna Circuit
  • B2502 - Auto Trans Shift Lock Control Shorted to Ground
  • B2503 - Park Gear (Auto Trans Shift Lock Control) Relay Shorted to Batt
  • B2507 - Voltage from climate control seat module (CCSM) is less than 2.0 volts or greater than 10 volts
  • B2510 - Steering Wheel Controls HVAC Key Stuck
  • B2511 - Steering Wheel Controls Conv Key Stuck
  • B2512 - Strng Wheel Controls Illegal A/D Values
  • B2515 - Strg Whl Cont Illegal Resistance Value
  • B2527 - Front Fog Lamp Circuit Low
  • B2530 - Front Foglamps Control Circuit
  • B2532 - Front Fog Lamps Control Circuit Low (BCM)
  • B2533 - Front Fog Lamps Control Circuit High (BCM)
  • B2540 - Rear Foglamps Control Circuit
  • B2550 - Storage Mode Entered (Backup Lamps Control Circuit)
  • B2556 - Interior Lamp Rheostat Circuit Range
  • B2560 - RKE Message Validation Error
  • B2575 - Headlamp Control Circuit
  • B2577 - Headlamp Relay Output Circuit Low (BCM)
  • B2578 - Headlamp Relay Output Circuit High (BCM)
  • B2580 - Headlamp High Beam Control Circuit
  • B2585 - Parklamp Control Circuit Malfunction
  • B2587 - Park Lamp Relay Output Circuit Low (BCM)
  • B2588 - Park Lamp Relay Output Circuit High (BCM)
  • B2600 - Daytime Running Lamp Control Circuit (BCM)
  • B2602 - Daytime Running Lamp Circuit Low (BCM)
  • B2603 - Daytime Running Lamp Circuit High (BCM)
  • B2610 - Passenger Compartment Dimming 1 Circuit
  • B2615 - Passenger Compartment Dimming 2 Circuit
  • B2620 - Display Dimming Input Circuit
  • B2622 - Display Dimming Pulse Width Modulation (PWM) Input Circuit Low (BCM)
  • B2623 - Display Dimming Pulse Width Modulation (PWM) Input Circuit High (BCM)
  • B2625 - Display Dimming Pulse Width Modulation (PWM) Output Circuit
  • B2627 - Display Dimming Pulse Width Modulation (PWM) Output Circuit Low (BCM)
  • B2628 - Display Dimming Pulse Width Modulation (PWM) Output Circuit High (BCM)
  • B2641 - Delayed Exterior Lighting Ctrl Circuit Range
  • B2645 - Ambient Light Sensor Circuit
  • B2646 - Ambient Light Sensor Circuit Range
  • B2647 - Ambient Light Sensor Circuit Low (BCM)
  • B2662 - Park Lamp Relay Output Circuit Low (BCM)
  • B2697 - Headlamp Washer Request Circuit
  • B2700 - Ignition Shift Interlock Circuit (base number)
  • B2701 - Ignition Shift Interlock Circuit Range/Performance
  • B2702 - Ignition Shift Interlock Circuit Low
  • B2703 - Ignition Shift Interlock Circuit High
  • B2704 - Ignition Shift Interlock Circuit Open
  • B2707 - Gearshift Unlock Circuit Low (BCM)
  • B2708 - Gearshift Unlock Circuit High (BCM)
  • B2710 - PASSKey Open/Shorted Pellet
  • B2711 - PASSKey Open/Shorted Pellet After Good Key
  • B2719 - CTD-Trunk Tamper Switch Fault
  • B2725 - ATC Mode Switch Circuit Malfunction
  • B2732 - Trunk Release Switch Circuit Low
  • B2734 - Coded Key Controller Memory Failure
  • B2743 - Fog Lamp Switch Circuit High (BCM)
  • B2750 - PASSKey Data Communication Failure
  • B2752 - Horn Relay Coil Circuit Low (BCM)
  • B2753 - Horn Relay Coil Circuit High (BCM)
  • B2757 - Driver Memory 1 Select Switch Circuit Low
  • B2762 - Driver Memory 2 Select Switch Circuit Low
  • B2767 - Memory Set Switch Failed Low
  • B2772 - Driver Memory Exit Switch Circuit Low
  • B2780 - Wrong Resistor Before Good
  • B2781 - Wrong Resistor After Good
  • B2782 - PASSKey Pellet Resistance Not Programmed
  • B2783 - Key Code/Password Corrupted in Memory
  • B2805 - Steering Whl Controls HVAC Switch Circuit Malfunction
  • B2810 - Steering wheel controls Entertainment Circuit Malfunction
  • B2815 - Steering Wheel Controls Illegal Resistance Value
  • B2853 - Telescope Forward Switch Circuit Malfunction
  • B2858 - Telescope Rearward Switch Circuit Malfunction
  • B2860 - Telescope Position Sensor Range
  • B2862 - Telescope Position Sensor Low
  • B2873 - Tilt Up Switch Circuit Malfunction
  • B2878 - Tilt Down Switch Circuit Malfunction
  • B2880 - Tilt Position Sensor Range
  • B2882 - Tilt Position Sensor Low
  • B2891 - Tilt/Telescope Motor Over Current
  • B2904 - Tilt/Telescope 4-way Position Switch Circuit Malfunction
  • B2947 - Security System Sensor Power Circuit Low
  • B2948 - Security System Sensor Power Circuit High
  • B2955 - Security System Sensor Data Circuit Malfunction
  • B2957 - Security System Sensor Data Circuit Low
  • B2958 - Security System Sensor Data Circuit High
  • B2960 - Security System Sensor Data Incorrect but Valid
  • B2961 - Key In Ignition Circuit Malfunction
  • B2965 - Key in Ignition Circuit Open (IPC)
  • B3028 - Starter Relay Interface Short to Ground
  • B3029 - Starter Relay Interface Open/Short to B+
  • B3031 - Key Decoder Device in Assem Learn Mode
  • B3033 - Security System Indicates Tamper
  • B3055 - Key Not Present
  • B3060 - Security System Sensor Data Incorrect but Valid
  • B3064 - Driver Door Key Cylinder Circuit
  • B3069 - Right Front/Left Front Door Key Unlock Circuit Low
  • B3108 - Transmitter Synchronization Failure
  • B3109 - 3 consecutive low battery signals from the same programmed transmitter
  • B3127 - LF Door Only, Unlock Circuit Low (BCM)
  • B3128 - LF Door Only, Unlock Circuit High (BCM)
  • B3132 - All Door Unlock Circuit Low (BCM)
  • B3133 - All Door Unlock Circuit High (BCM)
  • B3137 - All Door Lock Circuit Low (BCM)
  • B3138 - All Door Lock Circuit High (BCM)
  • B3142 - Left Front Unlock Switch Circuit Low
  • B3147 - Passenger Unlock Switch Circuit Low
  • B3152 - Left Front Lock Switch Circuit Low
  • B3157 - Passenger Lock Switch Circuit Low
  • B3172 - Window Up Switch Circuit Low
  • B3177 - Window Down Switch Circuit Low
  • B3182 - Window Switch Circuit
  • B3187 - Window Switch Circuit
  • B3192 - Window Switch Circuit
  • B3197 - Window Switch Circuit
  • B3203 - Rear Window Lockout Switch Input Circuit High
  • B3282 - Window Switch-Express Input Shorted to Ground
  • B3287 - Left Rear Window Switch Express Down Circuit Low
  • B3292 - Right Rear Window Switch Express Down Circuit Low
  • B3287 - Window Switch Circuit
  • B3292 - Window Switch Circuit
  • B3377 - Left Front Window Up Switch Circuit Low
  • B3382 - Left Front Window Down Switch Circuit Low
  • B3387 - Right Front Window Up Switch Circuit Low
  • B3392 - Right Front Window Down Switch Circuit Low
  • B3397 - Left Rear Window Up Switch Circuit Low
  • B3410 - AHLD Front Axle Sensor Signal Circuit
  • B3420 - AHLD Rear Axle Sensor Signal Circuit
  • B3452 - Left Rear Window Down Switch Circuit Low
  • B3457 - Right Rear Window Up Switch Circuit Low
  • B3462 - Right Rear Window Down Switch Circuit Low
  • B3467 - Left Front Window Express Down Circuit Low
  • B3472 - Right Front Window Express Down Circuit Low
  • B3477 - Left Rear Window Express Down Circuit Low
  • B3482 - MalfunctionWindow Express Down Circuit Low
  • B3517 - Left Rear Door Switch Express Up/Down Window Contact Shorted to GND
  • B3522 - Right Rear Door Switch Express Up/Down Window Contact Shorted to GND
  • B3527 - Window Lockout Switch Circuit Low
  • B3531 - Auxiliary HAVC Actuator Circuit
  • B3642 - Seat cool temperature switch shorted
  • B3702 - Intermittent Wiper Delay Input Circuit Low (BCM)
  • B3703 - Intermittent Wiper Delay Input Circuit High/Open (BCM)
  • B3708 - Front Washer Motor Input High (BCM)
  • B3713 - Rear Washer Motor Input Circuit High (BCM)
  • B3717 - Front Wiper Relay Drive Circuit Low (BCM)
  • B3718 - Front Wiper Relay Drive Circuit High (BCM)
  • B3722 - Rear Wiper Relay Drive Circuit Low (BCM)
  • B3723 - Rear Wiper Relay Drive Circuit High (BCM)
  • B3761 - HVAC Actuator Circuit
  • B3770 - HVAC Actuator Circuit
  • B3793 - Memory Seat Module Over Current
  • B3801 - Passenger Compartment Lamp Request Circuit
  • B3802 - Parklamps Request Circuit
  • B3808 - Rear Door Lock Relay Circuit
  • B3809 - Rear Door Unlock Relay Circuit
  • B3810 - Washer Relay Circuit
  • B3811 - Washer Relay Circuit
  • B3819 - Left Rear Power Window Up Relay Circuit
  • B3820 - Left Rear Power Window Down Relay Circuit
  • B3821 - Window Lockout Circuit Low
  • B3822 - Right Rear Power Window Up Relay Circuit
  • B3823 - Right Rear Power Window Down Relay Circuit
  • B3824 - Window Lockout Circuit Low
  • B3832 - Window Position Sensor Circuit
  • B3833 - Window Position Sensor Circuit
  • B3905 - Lumbar Switch Control Circuit
  • B3935 - Transponder Authentication Error
Chassis codes
  • C0000 - Vehicle Speed Information Circuit Malfunction
  • C0035 - Left Front Wheel Speed Circuit Malfunction
  • C0040 - Right Front Wheel Speed Circuit Malfunction
  • C0041 - Right Front Wheel Speed Sensor Circuit Range/Performance (EBCM)
  • C0045 - Left Rear Wheel Speed Circuit Malfunction
  • C0046 - Left Rear Wheel Speed Sensor Circuit Range/Performance (EBCM)
  • C0050 - Right Rear Wheel Speed Circuit Malfunction
  • C0051 - LF Wheel Speed Sensor Circuit Range/Performance (EBCM)
  • C0060 - Left Front ABS Solenoid #1 Circuit Malfunction
  • C0065 - Left Front ABS Solenoid #2 Circuit Malfunction
  • C0070 - Right Front ABS Solenoid #1 Circuit Malfunction
  • C0075 - Right Front ABS Solenoid #2 Circuit Malfunction
  • C0080 - Left Rear ABS Solenoid #1 Circuit Malfunction
  • C0085 - Left Rear ABS Solenoid #2 Circuit Malfunction
  • C0090 - Right Rear ABS Solenoid #1 Circuit Malfunction
  • C0095 - Right Rear ABS Solenoid #2 Circuit Malfunction
  • C0110 - Pump Motor Circuit Malfunction
  • C0121 - Valve Relay Circuit Malfunction
  • C0128 - Low Brake Fluid Circuit Low
  • C0141 - Left TCS Solenoid #1 Circuit Malfunction
  • C0146 - Left TCS Solenoid #2 Circuit Malfunction
  • C0151 - Right TCS Solenoid #1 Circuit Malfunction
  • C0156 - Right TCS Solenoid #2 Circuit Malfunction
  • C0161 - ABS/TCS Brake Switch Circuit Malfunction
  • C0221 - Right Front Wheel Speed Sensor Circuit Open
  • C0222 - Right Front Wheel Speed Signal Missing
  • C0223 - Right Front Wheel Speed Signal Erratic
  • C0225 - Left Front Wheel Speed Sensor Circuit Open
  • C0226 - Left Front Wheel Speed Signal Missing
  • C0227 - Left Front Wheel Speed Signal Erratic
  • C0229 - Drop Out of Front Wheel Speed Signals
  • C0235 - Rear Wheel Speed Signal Circuit Open
  • C0236 - Rear Wheel Speed Signal Circuit Missing
  • C0237 - Rear Wheel Speed Signal Erratic
  • C0238 - Wheel Speed Mismatch
  • C0241 - EBCM Control Valve Circuit
  • C0245 - Wheel Speed Sensor Frequency Error
  • C0254 - EBCM Control Valve Circuit
  • C0265 - EBCM Relay Circuit
  • C0266 - EBCM Relay Circuit
  • C0267 - Pump Motor Circuit Open/Shorted
  • C0268 - Pump Motor Circuit Open/Shorted
  • C0269 - Excessive Dump/Isolation Time
  • C0271 - EBCM Malfunction
  • C0272 - EBCM Malfunction
  • C0273 - EBCM Malfunction
  • C0274 - Excessive Dump/Isolation Time
  • C0279 - Powertrain Configuration Not Valid
  • C0281 - Brake Switch Circuit
  • C0283 - Traction Switch Shorted to Ground
  • C0284 - EBCM Malfunction
  • C0286 - ABS Indicator Lamp Circuit Shorted to B+
  • C0287 - Delivered Torque Circuit
  • C0288 - Brake Warning Lamp Circuit Shorted to B+
  • C0290 - Lost Communications With PCM
  • C0292 - Lost Communications With PCM
  • C0291 - Lost Communications With BCM
  • C0297 - Powertrain Configuration Data Not Received
  • C0298 - Powertrain Indicated Traction Control Malfunction
  • C0300 - Rear Speed Sensor Malfunction
  • C0305 - Front Speed Sensor Malfunction
  • C0306 - Motor A or B Circuit
  • C0308 - Motor A/B Circuit Low
  • C0309 - Motor A/B Circuit High
  • C0310 - Motor A/B Circuit Open
  • C0315 - Motor Ground Circuit Open
  • C0321 - Transfer Case Lock Circuit
  • C0323 - T-Case Lock Circuit Low
  • C0324 - T-Case Lock Circuit High
  • C0327 - Encoder Circuit Malfunction
  • C0357 - Park Switch Circuit High
  • C0359 - Four Wheel Drive Low Range (4LO) Discrete Output Circuit
  • C0362 - 4LO Discrete Output Circuit High
  • C0367 - Front Axle Control Circuit High
  • C0374 - General System Malfunction
  • C0376 - Front/Rear Shaft Speed Mismatch
  • C0379 - Front Axle System
  • C0387 - Unable to Perform Shift
  • C0472 - Steering Handwheel Speed Sensor Signal V Low
  • C0473 - Steering Handwheel Speed Sensor Signal V High
  • C0495 - EVO Tracking Error
  • C0498 - Steering Assist Control Actuator Feed Circuit Low
  • C0499 - Steering Assist Control Solenoid Feed Circuit High
  • C0503 - Steering Assist Control Solenoid Return Circuit Low
  • C0504 - Steering Assist Control Solenoid Return Circuit High
  • C0550 - ECU Malfunction - internal write / checksum malfunction
  • C0559 - EEPROM Checksum Error
  • C0563 - Calibration ROM Checksum Error
  • C0577 - Left Front Solenoid Circuit Low
  • C0578 - Left Front Solenoid Circuit High
  • C0579 - Left Front Solenoid Circuit Open
  • C0582 - Right Front Solenoid Circuit Low
  • C0583 - Right Front Solenoid Circuit High
  • C0584 - Right Front Solenoid Circuit Open
  • C0587 - Left Rear Solenoid Circuit Low
  • C0588 - Left Rear Solenoid Circuit High
  • C0589 - Left Rear Solenoid Circuit Open
  • C0592 - Right Rear Solenoid Circuit Low
  • C0593 - Right Rear Solenoid Circuit High
  • C0594 - Right Rear Solenoid Circuit Open
  • C0611 - VIN Information Error
  • C0615 - Left Front Position Sensor Malfunction
  • C0620 - Right Front Position Sensor Malfunction
  • C0625 - Left Rear Position Sensor Malfunction
  • C0628 - Level Control Position Sensor Circuit High
  • C0630 - Right Rear Position Sensor Malfunction
  • C0635 - Left Front Normal Force Circuit Malfunction
  • C0638 - Left Front Normal Force Circuit High
  • C0640 - Right Front Normal Force Circuit Malfunction
  • C0643 - Right Front Normal Force Circuit High
  • C0655 - Level Control Compressor Relay Malfunction
  • C0657 - Level Control Compressor Circuit Low
  • C0658 - Level Control Compressor Circuit High
  • C0660 - Level Control Exhaust Valve Circuit Malfunction
  • C0662 - Level Control Exhaust Valve Circuit Low
  • C0663 - Level Control Exhaust Valve Circuit High
  • C0665 - Chassis Pitch Signal Circuit
  • C0690 - Damper Control Relay Circuit Malfunction
  • C0691 - Damper Control Relay Circuit Range
  • C0693 - Damper Control Relay Circuit High
  • C0695 - Position Sensor Overcurrent (8 volt supply)
  • C0696 - Position Sensor Overcurrent (5 volt supply)
  • C0710 - Steering Position Signal Malfunction
  • C0750 - Tire Pressure Monitor (TPM) system sensor not transmitting
  • C0755 - Tire Pressure Monitor (TPM) system sensor not transmitting
  • C0760 - Tire Pressure Monitor (TPM) system sensor not transmitting
  • C0765 - Tire Pressure Monitor (TPM) system sensor not transmitting
  • C0800 - Device Power #1 Circuit Malfunction
  • C0896 - Electronic Suspension Control (ESC) voltage is outside the normal range of 9 to 15.5 volts
  • C1211 - ABS Indicator Lamp Circuit Malfunction
  • C1214 - System Relay Contact or Coil Circuit Open
  • C1217 - Pump Motor Shorted to Ground
  • C1218 - Pump Motor Circuit Shorted to Voltage or Motor Ground Open
  • C1221 - Left Front Wheel Speed Sensor Input Signal is 0
  • C1222 - Right Front Wheel Speed Sensor Input Signal is 0
  • C1223 - Left Rear Wheel Speed Sensor Input Signal is 0
  • C1224 - Right Rear Wheel Speed Sensor Input Signal is 0
  • C1225 - Left Front Excessive Wheel Speed Variation
  • C1226 - Right Front Excessive Wheel Speed Variation
  • C1227 - Left Rear Excessive Wheel Speed Variation
  • C1228 - Right Rear Excessive Wheel Speed Variation
  • C1232 - Left Front Wheel Speed Circuit Open or Shorted
  • C1233 - Right Front Wheel Speed Circuit Open or Shorted
  • C1234 - Left Rear Wheel Speed Circuit Open or Shorted
  • C1235 - Right Rear Wheel Speed Circuit Open or Shorted
  • C1236 - Low System Supply Voltage
  • C1237 - High System Supply Voltage
  • C1238 - Brake Thermal Model Exceeded
  • C1241 - Variable Effort Steering Circuit Malfunction
  • C1242 - Pump Motor Circuit Open
  • C1243 - BPMV Pump Motor Stalled
  • C1244 - Powertrain Indicated Engine Drag Control Malfunction
  • C1246 - Brake Lining Wear Circuit Open
  • C1248 - EBCM Turned the Red Brake Warning Indicator On
  • C1251 - RSS Indicated Malfunction
  • C1252 - Left Front Normal Force Malfunction
  • C1253 - Right Front Normal Force Malfunction
  • C1254 - Abnormal Shutdown Detected
  • C1255 - EBCM Internal Malfunction
  • C1256 - EBCM Internal Malfunction
  • C1261 - Left Front Inlet Valve Solenoid Malfunction
  • C1262 - Left Front Outlet Valve Solenoid Malfunction
  • C1263 - Right Front Inlet Valve Solenoid Malfunction
  • C1264 - Right Front Outlet Valve Solenoid Malfunction
  • C1265 - Left Rear Inlet Valve Solenoid Malfunction
  • C1266 - Left Rear Outlet Valve Solenoid Malfunction
  • C1267 - Right Rear Inlet Valve Solenoid Malfunction
  • C1268 - Right Rear Outlet Valve Solenoid Malfunction
  • C1271 - Left Front TCS Master Cylinder Isolation Valve Malfunction
  • C1272 - Left Front TCS Prime Valve Malfunction
  • C1273 - Right Front TCS Master Cylinder Isolation Valve Malfunction
  • C1274 - Right Front TCS Prime Valve Malfunction
  • C1276 - Delivered Torque Signal Circuit Malfunction
  • C1277 - Requested Torque Signal Circuit Malfunction
  • C1278 - TCS Temporarily Inhibited By PCM
  • C1281 - VSES Sensors Uncorrelated
  • C1282 - Yaw Rate Sensor Bias Circuit Malfunction
  • C1283 - Excessive Time to Center Steering
  • C1284 - Lateral Accelerometer Sensor Bias Malfunction
  • C1285 - Lateral Accelerometer Sensor Circuit Malfunction
  • C1286 - Steering Sensor Bias Malfunction
  • C1287 - Steering Sensor Rate Malfunction
  • C1288 - Steering Sensor Circuit Malfunction
  • C1291 - Open Brake Lamp Switch Contacts During Deceleration
  • C1292 - Brake Fluid Pressure Sensor Circuit
  • C1293 - Code C1291 Set in Previous Ignition Cycle
  • C1294 - Brake Lamp Switch Circuit Always Active
  • C1295 - Brake Lamp Switch Circuit Open
  • C1296 - Brake Fluid Pressure Sensor Circuit
  • C1297 - PCM Indicated Brake Extended Travel Switch Failure
  • C1298 - PCM Class 2 Serial Data Link Malfunction
  • C1326 - Battery Out of Range
  • C1650 - RSS Control Module Fault
  • C1658 - RSS Control Module Calibration Fault
  • C1710 - Left Front Damper Actuator Short Circuit to Battery
  • C1711 - Left Front Damper Actuator Short Circuit to Ground
  • C1712 - Left Front Damper Actuator Open Circuit
  • C1715 - Right Front Damper Actuator Short Circuit to Battery
  • C1716 - Right Front Damper Actuator Short Circuit to Ground
  • C1717 - Right Front Damper Actuator Open Circuit
  • C1720 - Left Rear Damper Actuator Short Circuit to Battery
  • C1721 - Left Rear Damper Actuator Short Circuit to Ground
  • C1722 - Left Rear Damper Actuator Open Circuit
  • C1725 - Right Rear Damper Actuator Short Circuit to Battery
  • C1726 - Right Rear Damper Actuator Short Circuit to Ground
  • C1727 - Right Rear Damper Actuator Open Circuit
  • C1735 - Compressor Relay Short to Battery
  • C1736 - Compressor Relay Short to GND/Open Circuit
  • C1737 - Exhaust Solenoid Valve Short to Battery
  • C1738 - Exhaust Solenoid Valve Short to GND
  • C1743 - Speed Signal Fault
  • C1744 - Lift/Dive Signal Discrete Fault
  • C1760 - Left Front Position Sensor Input Fault
  • C1761 - Right Front Position Sensor Input Fault
  • C1762 - Left Rear Position Sensor Input Fault
  • C1763 - Right Rear Position Sensor Input Fault
  • C1768 - Position Sensor Supply Fault
  • C1780 - Loss of Steering Position Signal
  • C1782 - ICCS2 DL Left Output Short Circuit to Bat
  • C1783 - ICCS2 DL Left Output Short Circuit to GND
  • C1784 - ICCS2 DL Right Output Short Circuit to Bat
  • C1785 - ICCS2 DL Right Output Short Circuit to GND
  • C1786 - Damper Control Relay Fault
  • C1787 - Damper Control Relay Short to GND
  • C1788 - Damper Control Relay Short to Bat
Powertrain codes
  • P0016 - Crankshaft Position Camshaft Position Correlation Bank 1 Sensor A
  • P0030 - Heated Oxygen Sensor (H02S) Heater Control Circuit Bank 1 Sensor 1
  • P0031 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 1
  • P0032 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 1
  • P0036 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
  • P0037 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 1 Sensor 2
  • P0038 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 1 Sensor 2
  • P0050 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 1
  • P0051 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 1
  • P0052 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 1
  • P0053 - HO2S Heater Resistance Bank 1 Sensor 1 (PCM)
  • P0054 - HO2S Heater Resistance Bank 1 Sensor 2 (PCM)
  • P0056 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 2
  • P0057 - Heated Oxygen Sensor (HO2S) Heater Circuit Low Voltage Bank 2 Sensor 2
  • P0058 - Heated Oxygen Sensor (HO2S) Heater Circuit High Voltage Bank 2 Sensor 2
  • P0068 - Throttle Body Airflow Performance (PCM)
  • P0100 - MAF Sensor Circuit Insufficient Activity
  • P0101 - Mass Air Flow (MAF) Sensor Performance
  • P0102 - Mass Air Flow (MAF) Sensor Circuit Low Frequency
  • P0103 - Mass Air Flow (MAF) Sensor Circuit High Frequency
  • P0104 - Mass Air Flow Circuit Intermittent
  • P0105 - MAP Sensor Circuit Insufficient Activity
  • P0106 - Manifold Absolute Pressure (MAP) System Performance
  • P0107 - Manifold Absolute Pressure (MAP) Sensor Circuit Low Voltage
  • P0108 - Manifold Absolute Pressure (MAP) Sensor Circuit High Voltage
  • P0109 - Manifold Absolute Pressure Circuit Intermittent
  • P0110 - Intake Air Temperature (IAT) Sensor Circuit
  • P0111 - Intake Air Temperature (IAT) Sensor Performance
  • P0112 - Intake Air Temperature (IAT) Sensor Circuit Low Voltage
  • P0113 - Intake Air Temperature (IAT) Sensor Circuit High Voltage
  • P0114 - Intake Air Temperature Circuit Intermittent
  • P0115 - Engine Coolant Temperature (ECT) Sensor Circuit
  • P0116 - Engine Coolant Temperature (ECT) Sensor Performance
  • P0117 - Engine Coolant Temperature (ECT) Sensor Circuit Low Voltage
  • P0118 - Engine Coolant Temperature (ECT) Sensor Circuit High Voltage
  • P0119 - Engine Coolant Temperature Circuit Intermittent
  • P0120 - TP System Performance
  • P0121 - TP Sensor Circuit Insufficient Activity
  • P0122 - Throttle Position (TP) Sensor Circuit Low Voltage
  • P0123 - Throttle Position (TP) Sensor Circuit High Voltage
  • P0124 - Throttle Position Sensor 1 Circuit Intermittent
  • P0125 - Engine Coolant Temperature (ECT) Insufficient for Closed Loop Fuel Control
  • P0126 - Insufficient ECT for Stable Operation
  • P0128 - Coolant Thermostat Below Thermostat Regulating Temperature
  • P0130 - Heated Oxygen Sensor (HO2S) Circuit Closed Loop (CL) Performance Bank 1 Sensor 1
  • P0131 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 1
  • P0132 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 1
  • P0133 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 1
  • P0134 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 1
  • P0135 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 1
  • P0136 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 2
  • P0137 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 2
  • P0138 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 2
  • P0139 - Heated Oxygen Sensor (HO2S) Slow Response Bank 1 Sensor 2
  • P0140 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 2
  • P0141 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 2
  • P0142 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 3
  • P0143 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 1 Sensor 3
  • P0144 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 1 Sensor 3
  • P0145 - Heated Oxygen Sensor (HO2S) Circuit Bank 1 Sensor 2 Slow Response
  • P0146 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 1 Sensor 3
  • P0147 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 1 Sensor 3
  • P0150 - Heated Oxygen Sensor (HO2S) Circuit Closed Loop (CL) Performance Bank 2 Sensor 1
  • P0151 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 1
  • P0152 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 1
  • P0153 - Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 1
  • P0154 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 1
  • P0155 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 2 Sensor 1
  • P0156 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 2
  • P0157 - Heated Oxygen Sensor (HO2S) Circuit Low Voltage Bank 2 Sensor 2
  • P0158 - Heated Oxygen Sensor (HO2S) Circuit High Voltage Bank 2 Sensor 2
  • P0159 - Heated Oxygen Sensor (HO2S) Slow Response Bank 2 Sensor 2
  • P0160 - Heated Oxygen Sensor (HO2S) Circuit Insufficient Activity Bank 2 Sensor 2
  • P0161 - Heated Oxygen Sensor (HO2S) Heater Performance Bank 2 Sensor 2
  • P0162 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3
  • P0163 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 Low Voltage
  • P0164 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 High Voltage
  • P0165 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 Slow Response
  • P0166 - Heated Oxygen Sensor (HO2S) Circuit Bank 2 Sensor 3 No Activity Detected
  • P0167 - Heated Oxygen Sensor (HO2S) Heater Circuit Bank 2 Sensor 3
  • P0169 - Fuel Composition Sensor
  • P0170 - Fuel Trim Bank 1
  • P0171 - Fuel Trim System Lean Bank 1
  • P0172 - Fuel Trim System Rich Bank 1
  • P0173 - Fuel Trim Bank 2
  • P0174 - Fuel Trim System Lean Bank 2
  • P0175 - Fuel Trim System Rich Bank 2
  • P0176 - Fuel Composition Sensor Circuit
  • P0177 - Fuel Composition Sensor Circuit Performance
  • P0178 - Fuel Composition Sensor Circuit Low Voltage
  • P0179 - Fuel Composition Sensor Circuit High Voltage
  • P0180 - Fuel Temperature Sensor 1 Circuit
  • P0181 - Fuel Temp. Sensor 1 Circuit Performance
  • P0182 - Fuel Temperature Sensor Circuit Low Voltage
  • P0183 - Fuel Temperature Sensor Circuit High Voltage
  • P0184 - Fuel Temperature Sensor 1 Circuit Intermittent
  • P0185 - Fuel Temperature Sensor 2 Circuit
  • P0186 - Fuel Temp. Sensor 2 Circuit Performance
  • P0187 - Fuel Temperature Sensor 2 Circuit Low Voltage
  • P0188 - Fuel Temperature Sensor 2 Circuit High Voltage
  • P0189 - Fuel Temperature Sensor 2 Circuit Intermittent
  • P0190 - Fuel Rail Pressure Sensor Circuit
  • P0191 - Fuel Rail Pressure Sensor Circuit Performance
  • P0192 - Fuel Rail Pressure Sensor Circuit Low Voltage
  • P0193 - Fuel Rail Pressure Sensor Circuit High Voltage
  • P0194 - Fuel Rail Pressure Sensor Circuit Intermittent
  • P0195 - Engine Oil Temperature Sensor
  • P0196 - Engine Oil Temperature Sensor Performance
  • P0197 - Engine Oil Temperature Sensor Low Voltage
  • P0198 - Engine Oil Temperature Sensor High Voltage
  • P0199 - Engine Oil Temperature Sensor Intermittent
  • P0200 - Injector Control Circuit
  • P0201 - Injector 1 Control Circuit
  • P0202 - Injector 2 Control Circuit
  • P0203 - Injector 3 Control Circuit
  • P0204 - Injector 4 Control Circuit
  • P0205 - Injector 5 Control Circuit
  • P0206 - Injector 6 Control Circuit
  • P0207 - Injector 7 Control Circuit
  • P0208 - Injector 8 Control Circuit
  • P0209 - Injector 9 Control Circuit
  • P0210 - Injector 10 Control Circuit
  • P0211 - Injector 11 Control Circuit
  • P0212 - Injector 12 Control Circuit
  • P0213 - Cold Start Injector 1
  • P0214 - Cold Start Injector 2
  • P0215 - Engine Shutoff Control Circuit
  • P0216 - Injection Timing Control Circuit
  • P0217 - Engine Overtemp Condition
  • P0218 - Transmission Fluid Overtemperature
  • P0219 - Engine Overspeed Condition
  • P0220 - APP Sensor 2 Circuit
  • P0221 - APP (Throttle Position) Sensor 2 Circuit Performance
  • P0222 - APP (Throttle Position) Sensor 2 Circuit Low Voltage
  • P0223 - APP (Throttle Position) Sensor 2 Circuit High Voltage
  • P0224 - Throttle Position Sensor 2 Intermittent
  • P0225 - APP Sensor 3 Circuit
  • P0226 - APP Sensor 3 Circuit Performance
  • P0227 - APP Sensor 3 Circuit Low Voltage
  • P0228 - APP Sensor 3 Circuit High Voltage
  • P0229 - Throttle Position Sensor 3 Intermittent
  • P0230 - Fuel Pump Relay Control Circuit
  • P0231 - Fuel Pump Feedback Circuit Low Voltage
  • P0232 - Fuel Pump Feedback Circuit High Voltage
  • P0233 - Fuel Pump Secondary Circuit Intermittent
  • P0234 - Turbocharger Engine Overboost Condition
  • P0235 - Turbocharger Boost Sensor 1 Circuit
  • P0236 - Turbocharger Boost System
  • P0237 - Turbocharger Boost Sensor Circuit Low Voltage
  • P0238 - Turbocharger Boost Sensor Circuit High Voltage
  • P0239 - Turbocharger Boost Sensor 2 Circuit
  • P0240 - Turbocharger Boost Sensor 2 Performance
  • P0241 - Turbocharger Boost Sensor 2 Circuit Low Voltage
  • P0242 - Turbocharger Boost Sensor 2 Circuit High Voltage
  • P0243 - Turbocharger Wastegate Solenoid 1
  • P0244 - Turbocharger Wastegate Solenoid 1 Performance
  • P0245 - Turbocharger Wastegate Solenoid 1 Low Voltage
  • P0246 - Turbocharger Wastegate Solenoid 1 High Voltage
  • P0247 - Turbocharger Wastegate Solenoid 2
  • P0248 - Turbocharger Wastegate Solenoid 2 Performance
  • P0249 - Turbocharger Wastegate Solenoid 2 Low Voltage
  • P0250 - Turbocharger Wastegate Solenoid 2 High Voltage
  • P0251 - Injection Pump Fuel Metering Control "A" Malfunction (Cam/Rotor/Injector)
  • P0252 - Injection Pump Fuel Metering Control "A" Range/Performance (Cam/Rotor/Injector)
  • P0253 - Injection Pump Fuel Metering Control "A" Low (Cam/Rotor/Injector)
  • P0254 - Injection Pump Fuel Metering Control "A" High (Cam/Rotor/Injector)
  • P0255 - Injection Pump Fuel Metering Control "A" Intermittent (Cam/Rotor/Injector)
  • P0256 - Injection Pump Fuel Metering Control "B" Malfunction (Cam/Rotor/Injector)
  • P0257 - Injection Pump Fuel Metering Control "B" Range/Performance (Cam/Rotor/Injector)
  • P0258 - Injection Pump Fuel Metering Control "B" Low (Cam/Rotor/Injector)
  • P0259 - Injection Pump Fuel Metering Control "B" High (Cam/Rotor/Injector)
  • P0260 - Injection Pump Fuel Metering Control "B" Intermittent (Cam/Rotor/Injector)
  • P0261 - Cylinder 1 Injector Circuit Low
  • P0262 - Cylinder 1 Injector Circuit High
  • P0263 - Cylinder 1 Contribution/Balance Fault
  • P0264 - Cylinder 2 Injector Circuit Low
  • P0265 - Cylinder 2 Injector Circuit High
  • P0266 - Cylinder 2 Contribution/Balance Fault
  • P0267 - Cylinder 3 Injector Circuit Low
  • P0268 - Cylinder 3 Injector Circuit High
  • P0269 - Cylinder 3 Contribution/Balance Fault
  • P0270 - Cylinder 4 Injector Circuit Low
  • P0271 - Cylinder 4 Injector Circuit High
  • P0272 - Cylinder 4 Contribution/Balance Fault
  • P0273 - Cylinder 5 Injector Circuit Low
  • P0274 - Cylinder 5 Injector Circuit High
  • P0275 - Cylinder 5 Contribution/Balance Fault
  • P0276 - Cylinder 6 Injector Circuit Low
  • P0277 - Cylinder 6 Injector Circuit High
  • P0278 - Cylinder 6 Contribution/Balance Fault
  • P0279 - Cylinder 7 Injector Circuit Low
  • P0280 - Cylinder 7 Injector Circuit High
  • P0281 - Cylinder 7 Contribution/Balance Fault
  • P0282 - Cylinder 8 Injector Circuit Low
  • P0283 - Cylinder 8 Injector Circuit High
  • P0284 - Cylinder 8 Contribution/Balance Fault
  • P0285 - Cylinder 9 Injector Circuit Low
  • P0286 - Cylinder 9 Injector Circuit High
  • P0287 - Cylinder 9 Contribution/Balance Fault
  • P0288 - Cylinder 10 Injector Circuit Low
  • P0289 - Cylinder 10 Injector Circuit High
  • P0290 - Cylinder 10 Contribution/Balance Fault
  • P0291 - Cylinder 11 Injector Circuit Low
  • P0292 - Cylinder 11 Injector Circuit High
  • P0293 - Cylinder 11 Contribution/Balance Fault
  • P0294 - Cylinder 12 Injector Circuit Low
  • P0295 - Cylinder 12 Injector Circuit High
  • P0296 - Cylinder 12 Contribution/Range Fault
  • P0300 - Engine Misfire Detected
  • P0301 - Cylinder 1 Misfire Detected
  • P0302 - Cylinder 2 Misfire Detected
  • P0303 - Cylinder 3 Misfire Detected
  • P0304 - Cylinder 4 Misfire Detected
  • P0305 - Cylinder 5 Misfire Detected
  • P0306 - Cylinder 6 Misfire Detected
  • P0307 - Cylinder 7 Misfire Detected
  • P0308 - Cylinder 8 Misfire Detected
  • P0309 - Cylinder 9 Misfire Detected
  • P0310 - Cylinder 10 Misfire Detected
  • P0311 - Cylinder 11 Misfire Detected
  • P0312 - Cylinder 12 Misfire Detected
  • P0313 - Misfire Detected With Low Fuel Level
  • P0315 - Crankshaft position (CKP) system variation values are not stored in the PCM memory
  • P0318 - Rough Road Sensor Circuit
  • P0320 - Ignition/Distributor Engine Speed Input Circuit Malfunction
  • P0321 - Ignition/Distributor Engine Speed Input Circuit Range/Performance
  • P0322 - IC Module 4X Reference Circuit No Frequency
  • P0323 - Ignition/Distributor Engine Speed Input Circuit Intermittent
  • P0324 - Knock Sensor (KS) Module Performance
  • P0325 - PCM Knock Sensor Circuit
  • P0326 - Knock Sensor Circuit Excessive Spark Retard
  • P0327 - Knock Sensor Circuit Low Voltage
  • P0328 - Knock Sensor 1 Circuit High Input (Bank 1 or Single Sensor)
  • P0329 - Knock Sensor 1 Circuit Intermittent (Bank 1 or Single Sensor)
  • P0330 - Knock Sensor (KS) Circuit Bank 2
  • P0331 - Knock Sensor 2 Circuit Range/Performance (Bank 2)
  • P0332 - Knock Sensor 2 Circuit Low Input (Bank 2)
  • P0333 - Knock Sensor 2 Circuit High Input (Bank 2)
  • P0334 - Knock Sensor 2 Circuit Intermittent (Bank 2)
  • P0335 - CKP Sensor A Circuit Performance
  • P0336 - Crankshaft Position (CKP) Sensor A Performance
  • P0337 - Crankshaft Position (CKP) Sensor Circuit Low Duty Cycle
  • P0338 - Crankshaft Position (CKP) Sensor Circuit High Duty Cycle
  • P0339 - Crankshaft Position (CKP) Sensor Circuit Intermittent
  • P0340 - Camshaft Position (CMP) Sensor Circuit
  • P0341 - Camshaft Position (CMP) Sensor Performance
  • P0342 - Camshaft Position Sensor Circuit Low Input
  • P0343 - Camshaft Position Sensor Circuit High Input
  • P0344 - Camshaft Position Sensor Circuit Intermittent
  • P0350 - Ignition Coil Primary/Secondary Circuit Malfunction
  • P0351 - Ignition Coil 1 Control Circuit
  • P0352 - Ignition Coil 2 Control Circuit
  • P0353 - Ignition Coil 3 Control Circuit
  • P0354 - Ignition Coil 4 Control Circuit
  • P0355 - Ignition Coil 5 Control Circuit
  • P0356 - Ignition Coil 6 Control Circuit
  • P0357 - Ignition Coil 7 Control Circuit
  • P0358 - Ignition Coil 8 Control Circuit
  • P0359 - Ignition Coil I Primary/Secondary Circuit Malfunction
  • P0360 - Ignition Coil J Primary/Secondary Circuit Malfunction
  • P0361 - Ignition Coil K Primary/Secondary Circuit Malfunction
  • P0362 - Ignition Coil L Primary/Secondary Circuit Malfunction
  • P0370 - Timing Reference High Resolution Signal A Malfunction
  • P0371 - IC 24X Reference Circuit Too Many Pulses
  • P0372 - IC 24X Reference Circuit Missing Pulses
  • P0373 - Timing Reference High Resolution Signal A Intermittent/Erratic Pulses
  • P0374 - Timing Reference High Resolution Signal A No Pulses
  • P0375 - Timing Reference High Resolution Signal B Malfunction
  • P0376 - Timing Reference High Resolution Signal B Too Many Pulses
  • P0377 - Timing Reference High Resolution Signal B Too Few Pulses
  • P0378 - Timing Reference High Resolution Signal B Intermittent/Erratic Pulses
  • P0379 - Timing Reference High Resolution Signal B No Pulses
  • P0380 - Glow Plug/Heater Circuit "A" Malfunction
  • P0381 - Glow Plug/Heater Indicator Circuit Malfunction
  • P0382 - Exhaust Gas Recirculation Flow Malfunction
  • P0385 - Crankshaft Position (CKP) Sensor B Circuit
  • P0386 - Crankshaft Position (CKP) Sensor B Performance
  • P0387 - Crankshaft Position Sensor B Circuit Low Input
  • P0388 - Crankshaft Position Sensor B Circuit High Input
  • P0389 - Crankshaft Position Sensor B Circuit Intermittent
  • P0400 - Exhaust Gas Recirculation Flow Malfunction
  • P0401 - Exhaust Gas Recirculation (EGR) Flow Insufficient
  • P0402 - Exhaust Gas Recirculation Flow Excessive Detected
  • P0403 - Exhaust Gas Recirculation (EGR) Solenoid Control Circuit
  • P0404 - Exhaust Gas Recirculation (EGR) Open Position Performance
  • P0405 - Exhaust Gas Recirculation (EGR) Position Sensor Circuit Low Voltage
  • P0406 - Exhaust Gas Recirculation Sensor A Circuit High
  • P0407 - Exhaust Gas Recirculation Sensor B Circuit Low
  • P0408 - Exhaust Gas Recirculation Sensor B Circuit High
  • P0410 - Secondary Air Injection (AIR) System
  • P0411 - Secondary Air Injection (AIR) System
  • P0412 - Secondary Air Injection (AIR) Solenoid Relay Control Circuit Bank 1
  • P0413 - Secondary Air Injection System Switching Valve A Circuit Open
  • P0414 - Secondary Air Injection System Switching Valve A Circuit Shorted
  • P0415 - Secondary Air Injection System Switching Valve B Circuit Malfunction
  • P0416 - Secondary Air Injection System Switching Valve B Circuit Open
  • P0417 - Secondary Air Injection System Switching Valve B Circuit Shorted
  • P0418 - Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 1
  • P0419 - Secondary Air Injection (AIR) Pump Relay Control Circuit Bank 2
  • P0420 - Catalyst System Low Efficiency
  • P0421 - Warm Up Catalyst Efficiency Below Threshold (Bank 1)
  • P0422 - Catalyst System Low Efficiency Bank 1
  • P0423 - Heated Catalyst Efficiency Below Threshold (Bank 1)
  • P0424 - Heated Catalyst Temperature Below Threshold (Bank 1)
  • P0430 - Catalyst System Low Efficiency Bank 2
  • P0431 - Warm Up Catalyst Efficiency Below Threshold (Bank 2)
  • P0432 - Catalyst System Low Efficiency Bank 2
  • P0433 - Heated Catalyst Efficiency Below Threshold (Bank 2)
  • P0434 - Heated Catalyst Temperature Below Threshold (Bank 2)
  • P0440 - Evaporative Emission (EVAP) System
  • P0441 - Evaporative Emission Control System Incorrect Purge Flow
  • P0442 - Evaporative Emission (EVAP) System Small Leak Detected
  • P0443 - EVAP Purge Solenoid Valve 1 Control Circuit
  • P0444 - Evaporative Emission Control System Purge Control Valve Circuit Open
  • P0445 - Evaporative Emission Control System Purge Control Valve Circuit Shorted
  • P0446 - EVAP Vent Solenoid Valve Control System
  • P0447 - Evaporative Emission Control System Vent Control Circuit Open
  • P0448 - Evaporative Emission Control System Vent Control Circuit Shorted
  • P0449 - Evaporative Emission (EVAP) Vent Solenoid Control Circuit
  • P0450 - Fuel Tank Pressure Sensor Circuit
  • P0451 - Evaporative Emission Control System Pressure Sensor Range/Performance
  • P0452 - Fuel Tank Pressure Sensor Circuit Low Voltage
  • P0453 - Fuel Tank Pressure Sensor Circuit High Voltage
  • P0454 - Evaporative Emission Control System Pressure Sensor Intermittent
  • P0455 - Evaporative Emission (EVAP) System Leak Detected
  • P0460 - Fuel Level Sensor Circuit
  • P0461 - Fuel Level Sensor Performance
  • P0462 - Fuel Level Sensor Circuit Low Voltage
  • P0463 - Fuel Level Sensor Circuit High Voltage
  • P0464 - Fuel Level Sensor Circuit Intermittent
  • P0465 - Purge Flow Sensor Circuit Malfunction
  • P0466 - Purge Flow Sensor Circuit Range/Performance
  • P0467 - Purge Flow Sensor Circuit Low Input
  • P0468 - Purge Flow Sensor Circuit High Input
  • P0469 - Purge Flow Sensor Circuit Intermittent
  • P0470 - Exhaust Pressure Sensor Malfunction
  • P0471 - Exhaust Pressure Sensor Range/Performance
  • P0472 - Exhaust Pressure Sensor Low
  • P0473 - Exhaust Pressure Sensor High
  • P0474 - Exhaust Pressure Sensor Intermittent
  • P0475 - Exhaust Pressure Control Valve Malfunction
  • P0476 - Exhaust Pressure Control Valve Range/Performance
  • P0477 - Exhaust Pressure Control Valve Low
  • P0478 - Exhaust Pressure Control Valve High
  • P0479 - Exhaust Pressure Control Valve Intermittent
  • P0480 - Cooling Fan Relay 1 Control Circuit
  • P0481 - Cooling Fan Relay 2 Control Circuit
  • P0482 - Cooling Fan 3 Control Circuit Malfunction
  • P0483 - Cooling Fan Rationality Check Malfunction
  • P0484 - Cooling Fan Circuit Over Current
  • P0485 - Cooling Fan Power/Ground Circuit Malfunction
  • P0496 - Evaporative Emission (EVAP) System Flow During Non-Purge
  • P0500 - Vehicle Speed Sensor (VSS) Circuit
  • P0501 - Vehicle Speed Sensor Range/Performance
  • P0502 - Vehicle Speed Sensor (VSS) Circuit Low Input
  • P0503 - Vehicle Speed Sensor (VSS) Circuit Intermittent
  • P0505 - Idle Control System Malfunction
  • P0506 - Idle Speed Low
  • P0507 - Idle Speed High
  • P0510 - Closed Throttle Position Switch Malfunction
  • P0512 - Start Switch Circuit
  • P0520 - Engine Oil Pressure Sensor/Switch Circuit Malfunction
  • P0521 - Engine Oil Pressure Sensor/Switch Circuit Range/Performance
  • P0522 - Engine Oil Pressure Sensor/Switch Circuit Low Voltage
  • P0523 - Engine Oil Pressure Sensor/Switch Circuit High Voltage
  • P0526 - Cooling Fan Speed Sensor Circuit
  • P0530 - A/C Refrigerant Pressure Sensor Circuit Malfunction
  • P0531 - A/C Refrigerant Pressure Sensor Circuit Range/Performance
  • P0532 - Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit Low Voltage
  • P0533 - Air Conditioning (A/C) Refrigerant Pressure Sensor Circuit High Voltage
  • P0534 - Air Conditioner Refrigerant Charge Loss
  • P0550 - Power Steering Pressure (PSP) Switch Circuit
  • P0551 - Power Steering Pressure Sensor Circuit Range/Performance
  • P0552 - Power Steering Pressure Sensor Circuit Low Input
  • P0553 - Power Steering Pressure Sensor Circuit High Input
  • P0554 - Power Steering Pressure Sensor Circuit Intermittent
  • P0560 - System Voltage
  • P0561 - System Voltage Unstable
  • P0562 - System Voltage Low (TCM)
  • P0563 - System Voltage High (TCM)
  • P0564 - Cruise Control Multi-Function Switch Circuit (PCM)
  • P0565 - Cruise Control On Signal Malfunction
  • P0566 - Cruise Control Off Signal Malfunction
  • P0567 - Cruise Control Resume Signal Malfunction
  • P0568 - Cruise Control Set Signal Malfunction
  • P0569 - Cruise Control Coast Signal Malfunction
  • P0570 - Cruise Control Accel Signal Malfunction
  • P0571 - Cruise Control Brake Switch Circuit
  • P0573 - Cruise Control/Brake Switch A Circuit High
  • P0574 - Vehicle Speed Too High - above 110 mph - Cruise Control Disabled
  • P0575 - Cruise Control Related Malfunction
  • P0576 - Cruise Control Related Malfunction
  • P0578 - Cruise Control Related Malfunction
  • P0579 - Cruise Control Related Malfunction
  • P0580 - Cruise Control Related Malfunction
  • P0600 - Serial Communication Link Malfunction
  • P0601 - Control Module Read Only Memory (ROM)
  • P0602 - Control Module Not Programmed
  • P0603 - Control Module Long Term Memory Reset
  • P0604 - Control Module Random Access Memory (RAM)
  • P0605 - Control Module Programming Read Only Memory (ROM)
  • P0606 - Control Module Internal Performance
  • P0607 - ECU Malfunction
  • P0608 - Control Module VSS Output "A" Malfunction
  • P0609 - Control Module VSS Output "B" Malfunction
  • P0610 - Control Module Vehicle Options Incorrect
  • P0615 - Starter Relay Control Circuit
  • P0616 - Starter Relay Control Circuit Low Voltage
  • P0617 - Starter Relay Control Circuit High Voltage
  • P0620 - Generator Control Circuit Malfunction
  • P0621 - Generator L-Terminal Circuit
  • P0622 - Generator F-Terminal Circuit
  • P0625 - Generator F-Terminal Circuit Low Voltage
  • P0626 - Generator F-Terminal Circuit High Voltage
  • P0628 - Fuel Pump Relay Control Circuit Low Voltage
  • P0629 - Fuel Pump Relay Control Circuit High Voltage
  • P0638 - Throttle Actuator Control (TAC) Command Performance
  • P0641 - PCM voltage out of tolerance condition on the 5-volt reference circuit
  • P0645 - Air Conditioning (A/C) Clutch Relay Control Circuit
  • P0646 - Air Conditioning (A/C) Clutch Relay Control Circuit
  • P0647 - Air Conditioning (A/C) Clutch Relay Control Circuit
  • P0650 - Malfunction Indicator Lamp (MIL) Control Circuit
  • P0651 - PCM voltage out of tolerance condition on the 5-volt reference circuit
  • P0654 - Engine RPM Output Circuit Malfunction
  • P0655 - Engine Hot Lamp Output Control Circuit Malfucntion
  • P0656 - Fuel Level Output Circuit Malfunction
  • P0660 - Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit
  • P0661 - Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit Low Voltage
  • P0662 - Intake Manifold Tuning (IMT) Valve Solenoid Control Circuit High Voltage
  • P0685 - Engine Controls Ignition Relay Control Circuit (PCM)
  • P0691 - Cooling Fan Relay Control Circuit Low Voltage
  • P0693 - Cooling Fan Relay Control Circuit Low Voltage
  • P0692 - Cooling Fan Relay Control Circuit High Voltage
  • P0694 - Cooling Fan Relay Control Circuit High Voltage
  • P0700 - Transmission Control System Malfunction
  • P0701 - Transmission Control System Range/Performance
  • P0702 - Transmission Control System Electrical
  • P0703 - Brake Switch Circuit Malfunction
  • P0704 - Clutch Switch Input Circuit Malfunction
  • P0705 - Trans Range Switch Circuit
  • P0706 - Trans Range Switch Performance
  • P0707 - Transmission Range Sensor Circuit Low Input
  • P0708 - Transmission Range Sensor Circuit High Input
  • P0709 - Transmission Range Sensor Circuit Intermittent
  • P0710 - Transmission Fluid Temperature Sensor Circuit Malfunction
  • P0711 - TFT Sensor Circuit Range/Performance
  • P0712 - Transmission Fluid Temperature (TFT) Sensor Circuit Low Input
  • P0713 - Transmission Fluid Temperature (TFT) Sensor Circuit High Input
  • P0714 - Transmission Fluid Temperature Sensor Circuit Intermittent
  • P0715 - Input/Turbine Speed Sensor Circuit Malfunction
  • P0716 - Input Speed Sensor Circuit Intermittent
  • P0717 - Input Speed Sensor Circuit Low Input
  • P0718 - Input/Turbine Speed Sensor Circuit Intermittent
  • P0719 - Brake Switch Circuit Low Input
  • P0720 - Output Speed Sensor Circuit Malfunction
  • P0721 - Output Speed Sensor Range/Performance
  • P0722 - Output Speed Sensor Circuit Low Input
  • P0723 - Output Speed Sensor Intermittent
  • P0724 - Brake Switch Circuit High Input
  • P0725 - Engine Speed Input Circuit
  • P0726 - Engine Speed Input Circuit Range/Performance
  • P0727 - Engine Speed Circuit No Signal
  • P0728 - Engine Speed Input Circuit Intermittent
  • P0730 - Incorrect Gear Ratio
  • P0731 - Incorrect 1st Gear Ratio
  • P0732 - Incorrect 2nd Gear Ratio
  • P0733 - Incorrect 3rd Gear Ratio
  • P0734 - Incorrect 4th Gear Ratio
  • P0735 - Gear 5 Incorrect ratio
  • P0736 - Reverse incorrect gear ratio
  • P0740 - TCC Enable Solenoid Circuit Electrical
  • P0741 - TCC System Stuck Off
  • P0742 - TCC System Stuck On
  • P0743 - TCC Enable Solenoid Circuit Electrical
  • P0744 - Torque Converter Clutch Circuit Intermittent
  • P0745 - Pressure Control Solenoid Malfunction
  • P0746 - Pressure Control Solenoid Performance or Stuck Off
  • P0747 - Pressure Control Solenoid Stuck On
  • P0748 - Pressure Control Solenoid Circuit Electrical
  • P0749 - Pressure Control Solenoid Intermittent
  • P0750 - Shift Solenoid A Malfunction
  • P0751 - 1-2 Shift Solenoid Valve Performance - No First or Fourth Gear
  • P0752 - 1-2 Shift Solenoid Valve Performance - No Second or Third Gear
  • P0753 - 1-2 Shift Solenoid Circuit Electrical
  • P0754 - Shift Solenoid A Intermittent
  • P0755 - Shift Solenoid B Malfunction
  • P0756 - 2-3 Shift Solenoid Valve Performance - No First or Second Gear
  • P0757 - 2-3 Shift Solenoid Valve Performance - No Third or Fourth Gear
  • P0758 - 2-3 Shift Solenoid Circuit Electrical
  • P0759 - Shift Solenoid B Intermittent
  • P0760 - Shift Solenoid C Malfunction
  • P0761 - Shift Solenoid C Performance or Stuck Off
  • P0762 - Shift Solenoid C Stuck On
  • P0763 - Shift Solenoid C Electrical
  • P0764 - Shift Solenoid C Intermittent
  • P0765 - Shift Solenoid D Malfunction
  • P0766 - Shift Solenoid D Performance or Stuck Off
  • P0767 - Shift Solenoid D Stuck On
  • P0768 - Shift Solenoid D Electrical
  • P0769 - Shift Solenoid D Intermittent
  • P0770 - Shift Solenoid E Malfunction
  • P0771 - Shift Solenoid E Performance or Stuck Off
  • P0772 - Shift Solenoid E Stuck On
  • P0773 - Shift Solenoid E Electrical
  • P0774 - Shift Solenoid E Intermittent
  • P0780 - Shift Malfunction
  • P0781 - 1-2 Shift Malfunction
  • P0782 - 2-3 Shift Malfunction
  • P0783 - 3-4 Shift Malfunction
  • P0784 - 4-5 Shift Malfunction
  • P0785 - 3-2 Shift Solenoid Circuit Electrical
  • P0786 - Shift/Timing Solenoid Range/Performance
  • P0787 - Shift/Timing Solenoid Low
  • P0788 - Shift/Timing Solenoid High
  • P0789 - Shift/Timing Solenoid Intermittent
  • P0790 - Normal/Performance Switch Circuit Malfunction
  • P0801 - Reverse Inhibit Control Circuit Malfunction
  • P0803 - 1-4 Upshift (Skip Shift) Solenoid Control Circuit Malfunction
  • P0804 - 1-4 Upshift (Skip Shift) Lamp Control Circuit Malfunction
  • P0850 - Park/Neutral Position (PNP) Switch Circuit
  • P0856 - Powertrain Indicated Traction Control Malfunction
  • P0894 - Transmission Component Slipping
  • P0897 - PCM detects a calculated transmission fluid life of 10 percent or less
  • P0962 - Line Pressure Control (PC) Solenoid Control Circuit Low Voltage (TCM)
  • P0963 - Line Pressure Control (PC) Solenoid Control Circuit High Voltage (TCM)
  • P0966 - Clutch Pressure Control (PC) Solenoid Control Circuit Low Voltage (TCM)
  • P0967 - Clutch Pressure Control (PC) Solenoid Control Circuit High Voltage (TCM)
  • P0970 - Shift Pressure control (PC) Solenoid Control Circuit Low Voltage (TCM)
  • P0971 - Shift Pressure Control (PC) Solenoid Control High Voltage (TCM)
  • P0973 - PCM detects an open or short to ground in the 1-2 SS valve circuit
  • P0974 - PCM detects a continuous short to voltage in the 1-2 SS valve circuit
  • P0976 - PCM detects a continuous open or short to ground in the 2-3 SS valve circuit
  • P0977 - PCM detects a continuous short to voltage in the 2-3 SS valve circuit
  • P0979 - Shift Solenoid (SS) 3 Control Circuit Low Voltage (TCM)
  • P0980 - Shift Solenoid (SS) 3 Control Circuit High Voltage (TCM)
  • P0982 - Shift Solenoid (SS) 4 Control Circuit High Voltage (TCM)
  • P0983 - Shift Solenoid (SS) 4 Control Circuit High Voltage (TCM)
  • P0985 - Shift Solenoid (SS) 5 Control Circuit Low Voltage (TCM)
  • P0986 - Shift Solenoid (SS) 5 Control Circuit High Voltage (TCM)
  • P1031 - Heated Oxygen Sensor (HO2S) Heater Current Monitor Control Circuit Banks 1 and 2 Sensor 1
  • P1032 - Heated Oxygen Sensor (HO2S) Heater Warm Up Control Circuit Banks 1 and 2 Sensor 1
  • P1101 - Actual measured airflow from MAF, MAP, EGR, and TP is not within range of the calculated airflow
  • P1105 - Secondary Vacuum Sensor Circuit
  • P1106 - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent High Voltage
  • P1107 - Manifold Absolute Pressure (MAP) Sensor Circuit Intermittent Low Voltage
  • P1108 - BARO to MAP Sensor Comparison Too High
  • P1109 - Secondary Port Throttle System
  • P1111 - Intake Air Temperature (IAT) Sensor Circuit Intermittent High Voltage
  • P1112 - Intake Air Temperature (IAT) Sensor Circuit Intermittent Low Voltage
  • P1113 - Intake Resonance Switchover Solenoid Control Circuit
  • P1114 - Engine Coolant Temperature (ECT) Sensor Circuit Intermittent Low Voltage
  • P1115 - Engine Coolant Temperature (ECT) Sensor Circuit Intermittent High Voltage
  • P1116 - ECT Signal Unstable or Intermittent
  • P1117 - Engine Coolant Temp. Signal Out-Of-Range Low
  • P1118 - Engine Coolant Temp. Signal Out-Of-Range High
  • P1119 - ECT Signal Out-Of-Range With TFT Sensor
  • P1120 - Throttle Position (TP) Sensor 1 Circuit
  • P1121 - Throttle Position (TP) Sensor Circuit Intermittent High Voltage
  • P1122 - Throttle Position (TP) Sensor Circuit Intermittent Low Voltage
  • P1125 - Accelerator Pedal Position (APP) System
  • P1130 - Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 1
  • P1131 - Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 1 Sensor 2
  • P1132 - Heated Oxygen Sensor (HO2S) Circuit Low Variance Bank 2 Sensor 1
  • P1133 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 1 Sensor 1
  • P1134 - Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 1
  • P1135 - Heated Oxygen Sensor (HO2S) Lean Mean Bank 1 Sensor 1
  • P1136 - Heated Oxygen Sensor (HO2S) Rich Mean Bank 1 Sensor 1
  • P1137 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Lean System or Low Voltage
  • P1138 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 2 Rich or High Voltage
  • P1139 - Heated Oxygen Sensor (HO2S) Insuff. Switching Bank 1 Sensor 2
  • P1140 - Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 1 Sensor 2
  • P1141 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 1 Sensor 2
  • P1143 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Lean System or Low Voltage
  • P1144 - Heated Oxygen Sensor (HO2S) Bank 1 Sensor 3 Rich or High Voltage
  • P1145 - Heated Oxygen Sensor (HO2S) Cross Counts Bank 1 Sensor 3
  • P1153 - Heated Oxygen Sensor (HO2S) Insufficient Switching Bank 2 Sensor 1
  • P1154 - Heated Oxygen Sensor (HO2S) Transition Time Ratio Bank 2 Sensor 1
  • P1155 - Heated Oxygen Sensor (HO2S) Lean Mean Bank 2 Sensor 1
  • P1156 - Heated Oxygen Sensor (HO2S) Rich Mean Bank 2 Sensor 1
  • P1157 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Lean System or Low Voltage
  • P1158 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 2 Rich or High Voltage
  • P1159 - Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 2
  • P1161 - Heated Oxygen Sensor (HO2S) Heater Control Circuit Bank 2 Sensor 2
  • P1163 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Lean System or Low Voltage
  • P1164 - Heated Oxygen Sensor (HO2S) Bank 2 Sensor 3 Rich or High Voltage
  • P1165 - Heated Oxygen Sensor (HO2S) Cross Counts Bank 2 Sensor 3
  • P1170 - Bank to Bank Fuel Trim Offset
  • P1171 - Fuel System Lean During Acceleration
  • P1172 - Fuel Transfer Pump Flow Insufficient
  • P1185 - Engine Oil Temperature Circuit
  • P1186 - EOT Circuit Performance
  • P1187 - EOT Sensor Circuit Low Voltage
  • P1188 - EOT Sensor Circuit High Voltage
  • P1189 - Engine Oil Pressure (EOP) Switch Circuit
  • P1190 - Engine Vacuum Leak
  • P1191 - Intake Air Duct Air Leak
  • P1200 - Injector Control Circuit
  • P1201 - (Alt. Fuel) Gas Mass Sensor Circuit Range/Performance
  • P1202 - (Alt. Fuel) Gas Mass Sensor Circuit Low Frequency
  • P1203 - (Alt. Fuel) Gas Mass Sensor Circuit High Frequency
  • P1211 - Mass Air Flow Circuit Intermittent High
  • P1212 - Mass Air Flow Circuit Intermittent Low
  • P1214 - Injection Pump Timing Offset
  • P1215 - Ground Fault Detection Indicated
  • P1216 - Fuel Solenoid Response Time Too Short
  • P1217 - Fuel Solenoid Response Time Too Long
  • P1218 - Injection Pump Calibration Circuit
  • P1219 - Throttle Position Sensor Reference Voltage
  • P1220 - Throttle Position (TP) Sensor 2 Circuit
  • P1221 - Fuel Pump Secondary Circuit Low
  • P1222 - Injector Control Circuit Intermittent
  • P1225 - Injector Circuit Cylinder 2 Intermittent
  • P1228 - Injector Circuit Cylinder 3 Intermittent
  • P1231 - Injector Circuit Cylinder 4 Intermittent
  • P1234 - Injector Circuit Cylinder 5 Intermittent
  • P1237 - Injector Circuit Cylinder 6 Intermittent
  • P1240 - Injector Circuit Cylinder 7 Intermittent
  • P1243 - Injector Circuit Cylinder 8 Intermittent
  • P1245 - Intake Plenum Switchover Valve
  • P1250 - Early Fuel Evaporation Heater Circuit
  • P1257 - Supercharger System Overboost
  • P1258 - Engine Coolant Overtemperature - above 268°F - Protection Mode Active
  • P1260 - Last Test Failed Failed SCC ENTER:More Info.
  • P1270 - Accelerator Pedal Position Sensor A/D Converter Error
  • P1271 - Accelerator Pedal Position (APP) Sensor 1-2 Correlation
  • P1272 - Accelerator Pedal Position Sensor 2
  • P1273 - "Accelerator Pedal Position Sensor 1
  • P1274 - Injectors Wired Incorrectly
  • P1275 - Accelerator Pedal Position (APP) Sensor 1 Circuit
  • P1276 - Accelerator Pedal Position Sensor 1 Circuit Performance
  • P1277 - Accelerator Pedal Position Sensor 1 Circuit Low Voltage
  • P1278 - Accelerator Pedal Position Sensor 1 Circuit High Voltage
  • P1280 - Accelerator Pedal Position (APP) Sensor 2 Circuit
  • P1281 - Accelerator Pedal Position Sensor 2 Circuit Performance
  • P1282 - Accelerator Pedal Position Sensor 2 Circuit Low Voltage
  • P1283 - Accelerator Pedal Position Sensor 2 Circuit High Voltage
  • P1285 - Accelerator Pedal Position Sensor 3 Circuit
  • P1286 - Accelerator Pedal Position Sensor 3 Circuit Performance
  • P1287 - Accelerator Pedal Position Sensor 3 Circuit Low Voltage
  • P1288 - Accelerator Pedal Position Sensor 3 Circuit High Voltage
  • P1300 - Ignitor Circuit
  • P1305 - Ignition Coil 2 Primary Feedback Circuit
  • P1310 - Ignition Coil 3 Primary Feedback Circuit
  • P1315 - Ignition Coil 4 Primary Feedback Circuit
  • P1320 - IC 4X Reference Circuit Intermittent
  • P1321 - Electronic Ignition System Fault Line
  • P1322 - EI System or Ignition Control Extra or Missing
  • P1323 - IC 24X Reference Circuit Low Frequency
  • P1324 - Crank RPM Too Low
  • P1335 - CKP Circuit
  • P1336 - Crankshaft Position (CKP) System Variation Not Learned
  • P1345 - Crankshaft Position (CKP)-Camshaft Position (CMP) Correlation
  • P1346 - Intake Camshaft Position [CMP] Sensor System Performance
  • P1350 - Ignition Control System
  • P1351 - Ignition Coil Control Circuit High Voltage
  • P1352 - IC Output High/Pulse Detected when GND_Cyl. 2
  • P1353 - IC Output High/Pulse Detected when GND_Cyl. 3
  • P1354 - IC Output High/Pulse Detected when GND_Cyl. 4
  • P1355 - IC Output High/Pulse Detected when GND_Cyl. 5
  • P1356 - IC Output High/Pulse Detected when GND_Cyl. 6
  • P1357 - IC Output High/Pulse Detected when GND_Cyl. 7
  • P1358 - IC Output High/Pulse Detected when GND_Cyl. 8
  • P1359 - Ignition Coil Group 1 Control Circuit
  • P1360 - Ignition Coil Group 2 Control Circuit
  • P1361 - Ignition Coil Control Circuit Low Voltage
  • P1362 - IC Cylinder 2 Not Toggling After Enable
  • P1363 - IC Cylinder 3 Not Toggling After Enable
  • P1364 - IC Cylinder 4 Not Toggling After Enable
  • P1365 - IC Cylinder 5 Not Toggling After Enable
  • P1366 - IC Cylinder 6 Not Toggling After Enable
  • P1367 - IC Cylinder 7 Not Toggling After Enable
  • P1368 - IC Cylinder 8 Not Toggling After Enable
  • P1370 - IC 4X Reference Circuit Too Many Pulses
  • P1371 - IC 4X Reference Circuit Too Few Pulses
  • P1372 - Crankshaft Position (CKP) Sensor A-B Correlation
  • P1374 - 3X Reference Circuit
  • P1375 - IC 24X Reference Circuit High Voltage
  • P1376 - Ignition Ground Circuit
  • P1377 - IC Cam Pulse To 4X Reference Pulse
  • P1380 - Misfire Detected - Rough Road Data Not Available
  • P1381 - Misfire Detected - No Communication with Brake Control Module
  • P1390 - Wheel Speed Sensor 1 - G - Sensor Circuit
  • P1391 - Wheel Speed Sensor 1 - G - Sensor Circuit Performance
  • P1392 - Wheel Speed Sensor 1 - G - Sensor Circuit Low Voltage
  • P1393 - Wheel Speed Sensor 1 - G - Sensor Circuit High Voltage
  • P1394 - Wheel Speed Sensor 1 - G - Sensor Circuit Intermittent
  • P1395 - Wheel Speed Sensor 2 - G - Sensor Circuit
  • P1396 - Wheel Speed Sensor 2 - G - Sensor Circuit Performance
  • P1397 - Wheel Speed Sensor 2 - G - Sensor Circuit Low Voltage
  • P1398 - Wheel Speed Sensor 2 - G - Sensor Circuit High Voltage
  • P1399 - Wheel Speed Sensor 2 - G - Sensor Circuit Intermittent
  • P1403 - Exhaust Gas Recirculation System Valve 1
  • P1404 - Exhaust Gas Recirculation (EGR) Closed Position Performance
  • P1405 - Exhaust Gas Recirculation System Valve 3
  • P1406 - EGR Valve Pintle Position Circuit
  • P1407 - EGR Air Intrusion in Exhaust Supply to EGR Valve
  • P1408 - Intake Manifold Pressure Sensor Circuit
  • P1409 - EGR Vacuum System Leak
  • P1410 - Fuel Tank Pressure System
  • P1415 - Secondary Air Injection (AIR) System Bank 1
  • P1416 - Secondary Air Injection (AIR) System Bank 2
  • P1418 - Secondary Air Injection System Relay A Control Circuit High
  • P1420 - Intake Air Low Pressure Switch Circuit Low Voltage
  • P1421 - Intake Air Low Pressure Switch Circuit High Voltage
  • P1423 - Intake Air High Pressure Switch Circuit High Voltage
  • P1431 - Fuel Level Sensor 2 Circuit Performance
  • P1432 - Fuel Level Sensor 2 Circuit Low Voltage
  • P1433 - Fuel Level Sensor 2 Circuit High Voltage
  • P1441 - Evaporative Emission (EVAP) System Flow During Non-Purge
  • P1442 - EVAP Vacuum Sw. High Voltage During Ign. On
  • P1450 - Barometric Pressure Sensor Circuit
  • P1451 - Barometric Press. Sensor Performance
  • P1460 - Cooling Fan Control System
  • P1480 - Cooling Fan 1 Control Circuit High
  • P1481 - Cooling Fan Speed Sensor Circuit
  • P1482 - Cooling Fan Speed Output Circuit
  • P1483 - Engine Cooling System Performance
  • P1484 - Cooling Fan System Performance
  • P1500 - Starter Signal Circuit
  • P1501 - Theft Deterrent System
  • P1501 - Vehicle Speed Sensor Circuit Intermittent
  • P1502 - Theft Deterrent Fuel Enable Signal Not Received
  • P1503 - Theft Deterrent Fuel Enable Signal Not Correct
  • P1504 - Vehicle Speed Output Circuit
  • P1508 - Idle Speed Low - Idle Air Control (IAC) System Not Responding
  • P1509 - Idle Speed High - Idle Air Control (IAC) System Not Responding
  • P1510 - Throttle Control System Performance - Throttle Limitation Active
  • P1511 - Throttle Control System - Backup System Performance
  • P1514 - Airflow to TP Sensor Correlation High
  • P1515 - Electronic Throttle System Throttle Position
  • P1516 - Throttle Actuator Control (TAC) Module Throttle Actuator Position Performance
  • P1517 - Electronic Throttle Module
  • P1518 - Electronic Throttle Module to PCM Communication
  • P1519 - Throttle Actuator Control (TAC) Module Internal Circuit
  • P1520 - Transmission Range Switch Circuit
  • P1521 - Transmission Engaged at High Throttle Angle
  • P1522 - Park/Neutral to Drive/Reverse at High RPM
  • P1523 - Throttle Closed Position Performance
  • P1524 - Throttle Closed Position Performance
  • P1525 - Throttle Body ServiceRequired
  • P1526 - Minimum Throttle Position Not Learned
  • P1527 - Transmission Range to Pressure Switch Correlation
  • P1528 - Governor
  • P1529 - Heated Windshield Request Problem
  • P1530 - Throttle Actuator Control (TAC) Module Internal Circuit
  • P1531 - A/C Low Side Temperature Sensor Fault
  • P1532 - A/C Evaporator Temp. Sens. Circuit Low Voltage
  • P1533 - A/C Evaporator Temp. Sens. Circuit High Voltage
  • P1534 - A/C High Side Temp. Sensor Low Voltage
  • P1535 - A/C High Side Temperature Sensor Circuit
  • P1536 - Engine Coolant Overtemperature - Air Conditioning (A/C) Disabled
  • P1537 - A/C Request Circuit Low Voltage
  • P1538 - A/C Request Circuit High Voltage
  • P1539 - A/C Clutch Status Circuit High Voltage
  • P1540 - Air Conditioning (A/C) Refrigerant Overpressure - Air Conditioning (A/C) Disabled
  • P1541 - A/C High Side Over Temperature
  • P1542 - A/C System High Pressure High Temperature
  • P1543 - A/C System Performance
  • P1544 - A/C Refrigerant Condition Very Low
  • P1545 - Air Conditioning (A/C) Clutch Relay Control Circuit
  • P1546 - A/C Clutch Status Circuit Low Voltage
  • P1547 - A/C System Performance Degraded
  • P1548 - A/C Recirculation Circuit
  • P1551 - Throttle Valve Rest Position Not Reached During Learn
  • P1554 - Cruise Control Feedback Circuit
  • P1555 - Electronic Variable Orifice Output
  • P1558 - Cruise Control Servo Indicates Low
  • P1559 - Cruise Control Power Management Mode
  • P1560 - Transaxle Not in Drive - Cruise Control Disabled
  • P1561 - Cruise Vent Solenoid
  • P1562 - Cruise Vacuum Solenoid
  • P1563 - Cruise Vehicle Speed/Set Speed Difference Too High
  • P1564 - Vehicle Acceleration Too High - Cruise Control Disabled
  • P1565 - Cruise Servo Position Sensor
  • P1566 - Engine RPM Too High - Cruise Control Disabled
  • P1567 - Active Banking Control Active - Cruise Control Disabled
  • P1568 - Cruise Servo Stroke Greater than Commanded in Cruise
  • P1569 - Cruise Servo Stroke High While not in Cruise
  • P1570 - Traction Control Active - Cruise Control Disabled
  • P1571 - Traction Control Torque Request Circuit
  • P1572 - ASR Active Circuit Low Too Long
  • P1573 - PCM/EBTCM Serial Data Circuit
  • P1574 - Stoplamp Switch Circuit
  • P1575 - Extended Travel Brake Switch Circuit
  • P1576 - BBV Sensor Circuit High Voltage
  • P1577 - BBV Sensor Circuit Low Voltage
  • P1578 - BBV Sensor Circuit Low Vacuum
  • P1579 - P/N to D/R at High Throttle Angle - Power Reduction Mode Active
  • P1580 - Cruise Move Circuit Low Voltage
  • P1581 - Cruise Move Circuit High Voltage
  • P1582 - Cruise Direction Circuit Low Voltage
  • P1583 - Cruise Direction CircuitHigh Voltage
  • P1584 - Cruise Control Disabled
  • P1585 - Cruise Control Inhibit Output Circuit
  • P1586 - Cruise Control Brake Switch 2 Circuit
  • P1587 - Cruise Control Clutch Control Circuit Low
  • P1588 - Cruise Control Clutch Control Circuit High
  • P1599 - Engine Stall or Near Stall Detected
  • P1600 - TCM Internal Watchdog Operation
  • P1601 - Serial Comm. Problem With Device 1
  • P1602 - Knock Sensor (KS) Module Performance
  • P1603 - Loss of SDM Serial Data
  • P1604 - Loss of IPC Serial Data
  • P1605 - Loss of HVAC Serial Data
  • P1606 - Serial Communication Problem With Device 6
  • P1607 - Serial Communication Problem With Device 7
  • P1608 - Serial Communication Problem With Device 8
  • P1609 - Loss Of TCS Serial Data
  • P1610 - Loss of PZM Serial Data
  • P1611 - Loss of CVRTD Serial Data
  • P1612 - Loss of IPM Serial Data
  • P1613 - Loss of DIM Serial Data
  • P1614 - Loss of RIM Serial Data
  • P1615 - Loss of VTD Serial Data
  • P1617 - Engine Oil Level Switch Circuit
  • P1619 - Engine Oil Life Monitor Reset Circuit
  • P1620 - Low Coolant Circuit
  • P1621 - Control Module Long Term Memory Performance
  • P1622 - Cylinder Select
  • P1623 - Transmission Temp Pull-Up Resistor
  • P1624 - Customer Snapshot Requested - Data Available
  • P1625 - TCM System Reset
  • P1626 - Theft Deterrent Fuel Enable Signal Not Received
  • P1627 - A/D Performance
  • P1628 - ECT Pull-Up Resistor
  • P1629 - Theft Deterrent System - Cranking Signal
  • P1630 - Theft Deterrent Learn Mode Active
  • P1631 - Theft Deterrent Start Enable Signal Not Correct
  • P1632 - Theft Deterrent Fuel Disable Signal Received
  • P1633 - Ignition 0 Switch Circuit
  • P1634 - Ignition 1 Switch Circuit
  • P1635 - 5 Volt Reference Circuit
  • P1636 - PCM Stack Overrun
  • P1637 - Generator L-Terminal Circuit
  • P1638 - Generator F-Terminal Circuit
  • P1639 - 5 Volt Reference 2 Circuit
  • P1640 - Driver-1-Input High Voltage
  • P1641 - Malfunction Indicator Lamp (MIL) Control Circuit
  • P1642 - Vehicle Speed Output Circuit
  • P1643 - Engine Speed Output Circuit
  • P1644 - Traction Control Delivered Torque Output Circuit
  • P1645 - Evaporative Emission (EVAP) Vent Solenoid Contorl Circuit
  • P1646 - Evaporative Emission (EVAP) Vent Solenoid Control Circuit
  • P1647 - Driver 1 Line 7
  • P1650 - Control Module Output B Circuit
  • P1651 - Fan 1 Relay Control Circuit
  • P1652 - Powertrain Induced Chassis Pitch Output Circuit
  • P1653 - Oil Level Lamp Control Circuit
  • P1654 - Cruise Control Inhibit Output Circuit
  • P1655 - EVAP Purge Solenoid Control Circuit
  • P1656 - Driver 2 Line 6
  • P1657 - 1-4 Upshift Solenoid Control Circuit
  • P1658 - Starter Enable Relay Control Circuit
  • P1660 - Cooling Fan Control Circuits
  • P1661 - MIL Control Circuit
  • P1662 - Cruise Lamp Control Circuit
  • P1663 - Oil Life Lamp Control Circuit
  • P1664 - 1-4 Upshift Lamp Control Circuit
  • P1665 - Driver 3 Line 5
  • P1666 - Driver 3 Line 6
  • P1667 - Reverse Inhibit Solenoid Control Circuit
  • P1669 - ABS Unit Expected
  • P1670 - Driver 4
  • P1671 - Driver 4 Line 1
  • P1672 - Low Engine Oil Level Lamp Control Circuit
  • P1673 - Engine Hot Lamp Control Circuit
  • P1674 - Tachometer Control Circuit
  • P1675 - EVAP Vent Solenoid Control Circuit
  • P1676 - Driver 4 Line 6
  • P1677 - Driver 4 Line 7
  • P1680 - Driver 5 (ECU Malfunction)
  • P1681 - Driver 5 Line 1
  • P1682 - Driver 5 Line 2
  • P1683 - Driver 5 Line 3
  • P1684 - Driver 5 Line 4
  • P1685 - Driver 5 Line 5
  • P1686 - Driver 5 Line 6
  • P1687 - Driver 5 Line 7
  • P1689 - Delivered Torque Circuit Fault
  • P1690 - ECM Loop Overrun
  • P1691 - Coolant Gage Circuit Low Voltage
  • P1692 - Coolant Gage Circuit High Voltage
  • P1693 - Tachometer Circuit Low Voltage
  • P1694 - Tachometer Circuit High Voltage
  • P1695 - Remote Keyless Entry Circuit Low
  • P1696 - Remote Keyless Entry Voltage High
  • P1700 - Transmission Control Module (TCM) Requested MIL Illumination
  • P1701 - Trans. MIL Request Circuit
  • P1705 - P/N Signal Output Circuit
  • P1719 - Incorrect Shifting Detected (TCM)
  • P1740 - Torque Reduction Signal Circuit
  • P1743 - TP Signal from ECM
  • P1760 - TCM Supply Voltage Interrupted
  • P1779 - Engine Torque Delivered to TCM Signal
  • P1780 - Park/Neutral Position [PNP] Switch Circuit
  • P1781 - Engine Torque Signal Circuit
  • P1790 - Transmission Control Module Checksum
  • P1791 - Transmission Control Module Loop
  • P1791 - Throttle/Pedal Position Signal (2000+)
  • P1792 - Transmission Control Module Reprogrammable Memory
  • P1792 - ECM to TCM Engine Coolant Signal
  • P1793 - Transmission Control Module Stack Overrun
  • P1793 - Wheel Speed Signal (2000+)
  • P1795 - CAN Bus - Throttle Body Position
  • P1800 - TCM Power Relay Control Circuit
  • P1801 - Performance Selector Switch Failure
  • P1804 - Ground Control Relay
  • P1810 - TFP Valve Position Switch Circuit
  • P1811 - Maximum Adapt and Long Shift
  • P1812 - Transmission Over Temperature Condition
  • P1813 - Torque Control
  • P1814 - Torque Converter Overstressed
  • P1815 - Transmission Range Switch - Start In Wrong Range
  • P1816 - TFP Valve Position Sw. - Park/Neu. With Drive Ratio
  • P1817 - TFP Valve Position Sw. - Reverse With Drive Ratio
  • P1818 - TFP Valve Position Sw. - Drive Without Drive Ratio
  • P1819 - Internal Mode Switch - No Start\Wrong Range
  • P1820 - Internal Mode Switch Circuit A Low
  • P1822 - Internal Mode Switch Circuit B High
  • P1823 - Internal Mode Switch Circuit P Low
  • P1825 - Internal Mode Switch - Invalid Range
  • P1826 - Internal Mode Switch Circuit C - High
  • P1831 - Pressure Control (PC) Solenoid Power Circuit - Low Voltage
  • P1832 - Pressure Control (PC)/Shift Lock Solenoid Control Circuit High Voltage
  • P1833 - A/T Solenoids Power Circuit - Low Voltage
  • P1834 - Torque Converter Clutch (TCC)/Shift Solenoid (SS) Control Circuit High Voltage
  • P1835 - Kick-Down Switch Circuit
  • P1836 - Kick-Down Switch Failed Open
  • P1837 - Kick-Down Switch Failed Short
  • P1842 - 1-2 Shift Solenoid Circuit Low Voltage
  • P1843 - 1-2 Shift Solenoid Circuit High Voltage
  • P1844 - Torque Reduction Signal Circuit Desired By TCM
  • P1845 - 2-3 Shift Solenoid Circuit Low Voltage
  • P1847 - 2-3 Shift Solenoid Circuit High Voltage
  • P1850 - Brake Band Apply Solenoid Circuit
  • P1851 - Brake Band Apply Solenoid Performance
  • P1852 - Brake Band Apply SolenoidLow Voltage
  • P1853 - Brake Band Apply Solenoid High Voltage
  • P1860 - TCC PWM Solenoid Circuit Electrical
  • P1864 - Torque Converter Clutch Circuit
  • P1865 - 4-5 Shift Solenoid (SS) Valve Control Circuit High Voltage
  • P1866 - Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit Low Voltage
  • P1867 - Torque Converter Clutch (TCC) Pulse Width Modulation (PWM) Solenoid Control Circuit High Voltage
  • P1868 - Transmission Fluid Life
  • P1870 - Transmission Component Slipping
  • P1871 - Undefined Gear Ratio
  • P1873 - TCC Stator Temp. Switch Circuit Low
  • P1874 - TCC Stator Temp. Switch Circuit High
  • P1875 - 4WD Low Switch Circuit Electrical
  • P1884 - TCC Enable/Shift Light Circuit
  • P1886 - Shift Timing Solenoid
  • P1887 - TCC Release Switch Circuit
  • P1890 - ECM Data Input Circuit
  • P1890 - Throttle Position Signal Input
  • P1891 - Throttle Position Sensor PWM Signal Low
  • P1892 - Throttle Position Sensor PWM Signal High
  • P1893 - Engine Torque Signal Low Voltage
  • P1894 - Engine Torque Signal High Voltage
  • P1895 - TCM to ECM Torque Reduction Circuit
  • P2008 - Intake Manifold Runner Control (IMRC) Solenoid Control Circuit
  • P2009 - Intake Manifold Runner Control (IMRC) Solenoid Control Circuit Low Voltage
  • P2010 - Intake Manifold Runner Control (IMRC) Solenoid Control Circuit High Voltage
  • P2066 - Fuel Level Sensor 2 Performance
  • P2067 - Fuel Level Sensor 2 Circuit Low Voltage
  • P2068 - Fuel Level Sensor 2 Circuit High Voltage
  • P2096 - Post Catalyst Fuel Trim System Low Limit
  • P2097 - Post Catalyst Fuel Trim System High Limit
  • P2098 - Post Catalyst Fuel Trim System Low Limit
  • P2099 - Post Catalyst Fuel Trim System High Limit
  • P2100 - Throttle Actuator Control (TAC) Motor Control Circuit
  • P2101 - Control Module Throttle Actuator Position Performance
  • P2105 - Throttle Actuator Control (TAC) System - Forced Engine Shutdown
  • P2107 - Throttle Actuator Control (TAC) Module Internal Circuit
  • P2108 - Throttle Actuator Control (TAC) Module Performance
  • P2119 - Throttle Closed Position Performance
  • P2120 - Accelerator Pedal Position (APP) Sensor 1 Circuit
  • P2121 - Accelerator Pedal Position (APP) Sensor 1 Performance
  • P2122 - Accelerator Pedal Position (APP) Sensor 1 Circuit Low Voltage
  • P2123 - Accelerator Pedal Position (APP) Sensor 1 Circuit High Voltage
  • P2125 - Accelerator Pedal Position (APP) Sensor 2 Circuit
  • P2127 - Accelerator Pedal Position (APP) Sensor 2 Circuit Low Voltage
  • P2128 - Accelerator Pedal Position (APP) Sensor 2 Circuit High Voltage
  • P2135 - Throttle Position (TP) Sensor 1-2 Correlation
  • P2138 - Accelerator Pedal Position (APP) Sensor 1-2 Correlation
  • P2176 - Minimum Throttle Position Not Learned
  • P2500 - Generator L-Terminal Circuit Low Voltage
  • P2501 - Generator L-Terminal Circuit High Voltage
  • P2535 - Ignition 1 Switch Circuit High Voltage (PCM)
  • P2610 - ECU Malfunction
  • P2763 - Short to voltage in the TCC Solenoid
  • P2764 - Open or Short to ground in the TCC PWM solenoid valve circuit
  • P2A00 - HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 1 (PCM)
  • P2A01 - HO2S Circuit Closed Loop (CL) Performance Bank 1 Sensor 2 (PCM)
  • P3000 - Hacking AWH Data
Network codes
  • U0001 - Controller Area Network (CAN) Bus Communication (ECM)
  • U1000 - Class 2 Communication Malfunction
  • U1001~U1254 - Loss of XXX Communications
  • U1002~U1015 - Loss of serial communications for class 2 devices
  • U1016 - Loss of Class 2 Communication with VCM
  • U1016 - Loss of Communications with PCM
  • U1017~U1025 - Loss of serial communications for class 2 devices
  • U1026 - Loss of ATC Class 2 Communication
  • U1027~U1039 - Loss of Serial Communications for Class 2 Devices
  • U1040 - Loss of Class 2 Communications with ABS
  • U1041 - Loss of EBCM Communication
  • U1042 - Lost Communications with Brake/Traction Control System
  • U1043~U1055 - Loss of Serial Communications for Class 2 Devices
  • U1056 - Loss of Communications with RSS
  • U1057~U1060 - Loss of Serial Communications for Class 2 Devices
  • U1161 - Loss of PDM Serial Data
  • U1062 - Loss of Serial Communications for Class 2 Devices
  • U1163 - Loss of RRDM Serial Data
  • U1064 - Loss of Communications with DIM
  • U1065 - Loss of Communications with IPM
  • U1066 - Loss of Communications with RIM
  • U1067~U1069 - Loss of Serial Communications for Class 2 Devices
  • U1170 - Loss of Driver Door Switch Asm Serial Data
  • U1071~U1087 - Loss of Serial Communications for Class 2 Devices
  • U1088 - Loss of Communications with SDM
  • U1089~U1095 - Loss of Serial Communications for Class 2 Devices
  • U1096 - Loss of Communications with IPC
  • U1097~U1127 - Loss of serial communications for class 2 devices
  • U1128 - Loss of Communications with IRC
  • U1129 - Loss of Communications with AMP
  • U1130~U1143 - Loss of serial communications for class 2 devices
  • U1144 - Loss of Communications with PHN
  • U1145 - Loss Of NAV Communications
  • U1146 - Loss Of Onstar Communiction
  • U1147~U1151 - Loss of serial communications for class 2 devices
  • U1152 - Loss Of ACM Serial Data Communication
  • U1152 - Loss of Data HCM
  • U1153 - Loss of Communications with CCP
  • U1154~U1159 - Loss of serial communications for class 2 devices
  • U1160 - Loss of Communications with DDM
  • U1161 - Loss of PASS Door Module SBI
  • U1162 - Loss of Rear Driver Door Module SBI
  • U1163 - Loss of Rear PASS Door Module SBI
  • U1164 - Loss Of DIM Serial Data Communication
  • U1165 - Loss of serial communications for class 2 devices
  • U1166 - Loss of Communications with SCM
  • U1167 - Loss of serial communications for class 2 devices
  • U1168 - Loss Of TTM Communications
  • U1169 - Loss of Communications with MMM
  • U1170 - Loss of Driver Door Switch SBI
  • U1171~U1175 - Loss of serial communications for class 2 devices
  • U1176 - Loss Of RFA Communications
  • U1177~U1191 - Loss of serial communications for class 2 devices
  • U1192 - Loss of VTD Class 2 Serial Data Com
  • U1193 - Loss of VIM Class 2 Communication
  • U1194~U1254 - Loss of serial communications for class 2 devices
  • U1255 - Class 2 Communication Malfunction (Serial Data Line Malfunction)
  • U1300 - Class 2 Short to Ground
  • U1301 - Class 2 Short to Battery
  • U1304 - Loss Of UART Communications
  • U1305 - Class 2 Data Link Low or High
  • U1500 - Inter-Device Dedicated Bus Malfunction
  • U1713 - Loss of Front Door Module to Window Motor High Speed Comm.
  • U1715 - Loss of Front Door Module to Window Motor High Speed Comm.
  • U1714 - Loss of Front Door Module to Window Motor Normal Speed Comm.
  • U1716 - Loss of Front Door Module to Window Motor Normal Speed Comm.
  • U1800 - Controller Area Network (CAN) Bus Communication
  • U2000 - Invalid BFC Transmitted SPI Data
  • U2001 - Invalid IPC Transmitted SPI Data
  • U2002 - SPI Data-In Low
  • U2003 - SPI Data-In High
  • U2004 - SPI Data-Out Low
  • U2005 - SPI Data-Out High
  • U2006 - SPI Clock-Out Low
  • U2007 - SPI Clock-Out High
  • U2050 - SIR PPS/CPS Communications Link malfunction
  • U2100 - Controller Area Network (CAN) Bus OFF
  • U2100 - CAN-BUS Communication Malfunction
  • U2102 - More Controllers on Bus than Programmed
  • U2103 - Fewer Controllers On Bus Than Programmed
  • U2104 - CAN Bus Reset Counter Overrun
  • U2105 - CAN Bus Error ECM
  • U2105 - Lost Comm with Engine Control System
  • U2106 - Lost Comm with Trans Control System
  • U2107 - Lost Communications with Body Control System
  • U2108 - CAN Bus Error ABS
  • U2108 - Lost Comm with ABS Control System
  • U2150 - Navigation ECU Gateway Communication Error
  • U2151 - Navigation ECU Communication Malfunction
  • U2153 - VICS ECU Communication Error
vay ne çok hata varmış :) :) :)
Moderatör tarafında düzenlendi:
ne denirki haklısın
Ellerine Sağlık Harika bi kaynak...
tesekkur ederim
hocam bu hata kodları hani bu arabaya taktıkları bilgisayardamı çıkıyor biraz açıklama yapariseniz sevinirim teşekürler
