- 28 Nis 2013
- Yaş
- 32
Ynt: active select güncelleme
Bence Bu Active Selectin ozelikleri degil. Cunku vites oranlar bu olamaz ben 5 viteste 5500 devir 225kmh goruyorum, hesaplama gore 5 vites 6500 devir 205kmh.
bizim ki bu asagidaki olmasi lazim sadece final drive orani degisik 3.23
Transmission / Gear ratio
1th gear ratio: 4,58:1
2th gear ratio: 2,96:1
3th gear ratio: 1,91:1
4th gear ratio: 1,45:1
5th gear ratio: 1,00:1
6th gear ratio: 0,75:1
7th gear ratio: -
8th gear ratio: -
9th gear ratio: -
Reverse gear ratio: 2,94:1
Gear Ratio (end): 3,23:1
RPM at 120 km/h (theoretical): 2.400 rpm
HESAPLAMA ASAGIDA ( 1. HESAPLAMA FINAL DRIVE 3.87 / 2. HESAPLAMA FINAL DRIVE 3.23 )
http://www.teammfactory.com/gearcalculator.php?kmh=1&tirewidth=215&tireprofile=50&wheelsize=17&tirediameter1=25.46&maxrpm1=6500&finaldrive1=3.87&gearratio1=4.58&gearratio2=2.96&gearratio3=1.91&gearratio4=1.45&gearratio5=1&gearratio6=0.75&trannytype=&tirewidth2=215&tireprofile2=50&wheelsize2=17&tirediameter2=25.46&maxrpm2=6500&finaldrive2=3.23&gearratioa=4.58&gearratiob=2.96&gearratioc=1.91&gearratiod=1.45&gearratioe=1&gearratiof=0.75&trannytype=&tranny=Calculate+Transmission+1+%26+2
ulas79 link' Alıntı:valla ustaya neden haber vermediniz diye sorduğumda yazılımın daha 1-2 ay önce geldiğini söyledim ,bu arada 1.6T ve 1.4T nin şanzıman kodu aynı 6t 40 şanzıman aşağıda teknik özelliklerini paylaşıyorum
Hydra-Matic 6T40 (MH8)
Type: Six speed front-wheel-drive, electronically controlled, automatic overdrive transaxle with an electronically controlled torque converter clutch.
Maximum Engine powerhp/kW ) 180 hp ( 134 kW )
Maximum engine torque: 177 lb-ft (240 Nm)
Maximum gearbox torque: 277 lb-ft (375 Nm) - All gears
Gear ratios: MH8
First:4.58
Second: 2.96
Third: 1.91
Fourth: 1.45
Fifth: 1.00
Sixth: 0.75
Reverse: 2.94
Final Drive Ratio: 3.87
Maximum input speed: Rev 4000 rpm
1-2 7000 rpm
2-3 7000 rpm
3-4 7000 rpm
4-5 7000 rpm
5-6 6000 rpm (corresponds to 4476 rpm in 6th after the shift is complete)
Maximum input speed in 6th: 4476 rpm
Maximum validated gross vehicle weight: 1996 kg (4400 lbs)
Shifter Posistions: P, R, N, D, M
Case material: die cast aluminum
Shift pattern: Variable Flow Solenoids
Shift quality: Variable Flow Solenoids
Torque converter clutch: Variable Bleed Solenoid
Converter size: 236mm (reference) (diameter of torque converter turbine)
Fluid type: DEXRON® VI
Transmission weight: wet: 82 kg (180.4 lb)
Fluid capacity (approximate): 7.77L (6.56 kg)
Bottom pan removal: NA
Pressure taps available: Line Pressure
Transfer design: Two-axis design, Output Chain
Assembly sites: GMK (Korea), SGM (China), SLP (Mexico), TTO (Toledo).
Applications: Chevrolet Malibu & Cruze, Buick Regal & Verano
7th gear ratio: -
8th gear ratio: -
9th gear ratio: -
