Tesisat kurmaya karar verdim sizce bu set nasıl
Sizce nasıl
  • Kullanılan toplam oy
    21
yusufaltintepe
29 Ağu 2006
Arkadaşlar sistem değişti yeni fikirleri bekliyorum.
PIONEER AVH-P 6050 DVD
  • <LI hasbox="2">7" Touch Panel LCD Display <LI hasbox="2">24 bit DAC <LI hasbox="2">6-disc DVD changer <LI hasbox="2">iPod adapter ready <LI hasbox="2">4-mode Staging DFP <LI hasbox="2">3 RCA pre-outs
  • 2 AV-Inputs
ZXC-6KIT
6.5" 2-WAY COMPONENT KIT ( 2 takım alacağım)
  • 6.5" 4 Ohm Woofer
  • High Power Voice Coil
  • Flush/Angle/Surface Mount Silk Sift Dome Tweeter
  • RMS Power: 100
  • Peak Power: 200
  • Frequency Response: 65Hz-22KHz
  • Sensitivity: 93db @ 1W/1M
  • Mounting Depth: 2-3/4"
  • Butyl Rubber Surround
  • Areo Dimple Aluminum Cone Technology
  • Zobel Crossover Network with +/- 3db Tweeter Equalization
  • 1 Year Warranty
AUDISON LRX1 AMFİ SUB İÇİN
  • 900 Watt Monoblock Amplifier
  • RMS Power Ratings:
    • 350Wx 1 @ 4 Ohms
    • 650Wx 1 @ 2 Ohms
    • 900Wx 1 @ 1 Ohm
  • Limit Led: Overload Protection Circuit Indicator
  • On/Off Led
  • Safety Led
  • Subsonic Bypass
  • Output level adjustment
  • Phase inverter (0°-180°)
  • F1Q: Lo-Pass filter Q factor adjustment
  • Built-in Crossovers: HPF(40 - 500Hz), LPF(40 - 500Hz)
  • Subsonic Filter: Pre-set @ 20 Hz, Adjustable from 16 - 32Hz by replacing special resistors
  • 1 Pair RCA Outputs: Hi-Pass or Bypass
  • Optional Bass Remote Modules Available Seperatley
  • Dimensions: 370mm x 176mm x 56mm (LxWxH)
AUDISON SRX4 COMP. İÇİN
4 kanals effektforsterker med delefilter
Høypass filter front/bak 50-220Hz trinnløst justerbart 12dB
Lavpass filter bak 50-220Hz trinnløst justerbart 12dB
RMS Effekt @13,8V 4Ohm: 4 x 60W
RMS Effekt @13,8V 2Ohm: 4 x 85W
RMS Effekt @13,8V 4Ohm mono: 2 x 170W
Stabil 2 Ohm stereo / 4 Ohm mono
Signal/støy forhold (A weighed): 95dB
THD @ 1KHz, 4Ohm: 0,05%
RCA innganger: Front/bak L/R
RCA utganger: L/R By-pass
Mål (H x B x L): 49,5mm x 175mm x 304mm
JL AUDIO 12W6V2
Free Air Resonance (Fs): 25.0 HzElectrical “Q” (Qes): 0.480Mechanical “Q” (Qms): 7.100Total Speaker “Q” (Qts): 0.450Equivalent Compliance (Vas): 2.82 cu. ft. / 79.9 litersOne-Way, Linear Excursion (Xmax)*: 0.65 in. / 16.5 mmReference Efficiency (no): 0.250%Efficiency (1W/1m)**: 85.9 dB SPLEffective Piston Area (Sd): 77.8 sq. in. / 0.0502 sq. m.DC Resistance (Re): 6.75 ohm***Nominal Impedance (Znom): Dual 4 ohmThermal Power Handling (Pt): 600WDriver Displacement: 0.090 cu. ft. / 2.5 litersNet Weight: 19.4 lbs. / 8.8 kg
Hayırlı olsun Yusuf Umarım herşey istediğin gibi olur Honda crv yi disko yapmaya karar vermişsin :)
mid leri iyi bir şey al morel mesela
ucuz ama iyi bir şey olsn dersen lanzar al alman malıdır. mesela bende var mubarek iki kolonla araba salıyor 17cm sanırsam ama 180Rms
midler zaten yeterince kaliteli değilmi cadence amerikan çifti 500 ytl ye geliyor bana
ne 500ytl mi yapma arkadaşım ben pek cadence anlamam ama o kadar para verme yaa. morel 1 numara dır bilgine
çifti derken kastım 2 takımı 500 ytl ama cadence de kaliteli ve kendini kanıtlamış bir markadır ama tavsiyelere açığım tabi :)
sistem gayet güzel ama biraz fazla ses açtığında komp.lar yetersiz kalmaz umarım yapma şansın varsa 3 tk yap derim komp.ları :)
3 takımı malesef yapamam yerim yok ama comp. lar 2 takımı yeterli gelir kanımca olmassa sub. 250 wt. rms bir modeli daha var onu alırım ama sen neden yetersiz olacağını düşündün Murat birde configurasyon nasıl sence abi uyum yada uyumsuzluk varmı ben sub konusunda çok takıldım marka olarak ise cadence ye senin yorumun ne olur
