benzinde yeni tasarruf yöntemi (ingilizce)
Al Paciona
11 Kas 2008
Official Statement on MPG-CAP™ Performance Characteristics
There appears to be a need for clarification about the technology behind the FFi MPG-CAPS™ due to confusion caused by other less credible fuel additives with similar sounding marketing claims.
First of all, the majority of fuel additives, treatments, and conditioners sold today are merely detergents that serve to clean the fuel system but do nothing to the combustion characteristics of fuel or, more importantly, to the combustion chamber itself. This is the arena in which FFi technology and products are formulated to perform, providing the distinction between our products and all the others.
Since most automobile engines burn fuel at a rate of more than 99% efficiency, claims of improving combustion alone are essentially meaningless. However, the greatest loss in the efficiency of an automobile engine is the loss of heat which drives the piston. Experts in the combustion field say that heat recovery is the only practical way to improve gas mileage on a modern engine. Our product is a combustion chamber treatment that conditions the setting where fuel combustion occurs so that the process uses more of the heat generated by combustion.
Here is the way it works. When an MPG-CAP™ is added to the fuel tank, the fuel carries it to the combustion chamber. Its ingredients are used to treat the metal surfaces by forming a film that is technically called thermally derived oxidation. The carboxylic metal creates an oxide residue on the hot surfaces at the time of combustion.
This process can be compared to the scorching of a pan when cooking. When overheated, the food residue forms a layer on the pan when it is oxidized, leaving a film even after being scrubbed that discolors the pan and appears to permeate the pores of the metal.
Inside an engine cylinder, small amounts of material provided by the MPG-CAPS™ oxidize in high temperatures, rapidly producing a thin layer of film on the cylinder walls, the piston face, and the fire deck that provide several benefits.
First of all, the MPG-CAPS™ change the surface heat absorption characteristics of the metal. The fuel and air mixture produces energy in the form of heat that creates expansion that drives the piston down, and the film inhibits the transfer of radiant heat. This directly results in higher combustion temperature, greater expansion, and more power.
The second benefit the MPG-CAP™ film provides is a polished surface effect that allows more even distribution of the fuel. It can be compared to the beading of water on a polished paint job. The micro film attracts the liquid fuel resulting in better fuel distribution that shapes the charge to yield more power.
The third benefit of the film is by serving as a catalyst precursor to react with the catalyst component in the MPG-CAPS™ themselves. The active compounds of the MPG-CAPS™ in combination with the heat in the cylinder cause a catalytic reaction that promotes better disassociation of chemicals and better burn. The catalytic reaction is also exothermic and produces heat. Altogether, these three benefits result in a total of 30 to 40% more expansion in the cylinder with an equal amount of fuel.
Another factor to be considered is the ability of the film created by the MPG-CAPS™ to inhibit the build-up of harmful deposits. This is particularly important in view of the effects that the EPA regulations have had on the automobile industry. In order to comply with EPA mandates to lower emissions, fuel manufacturers have removed lead and added oxygenates to fuel. The repercussion is the building of harmful deposits that tend to soak up fuel and cause performance problems. Decreasing the extent of those deposits is yet another benefit of our product.
Lastly, and perhaps most importantly of all, is the reduction of emissions resulting from the use of MPG-CAPS™. The catalytic process found in catalytic converters on exhaust systems is started in the firing cylinder, which reduces the formation of nitrogen oxides (NOx). The work done by the converter is reduced, and life of the converter is extended.
Extensive scientific testing has revealed many positive effects of FFi products, and none that are negative. Distributors and customers have the added security of a world wide insurance policy that covers any possibility of engine damage. There is every reason to be confident in the abilities of the MPG-CAPS to make a favorable difference in your world.
MPG-CAPS™
Use as directed on the chart below.
Printable MPG-CAPS™ usage chart
Do not exceed the
recommended doses.
Current 0,5 Gram Caplet
Conditioning
dose
First tank only
Regular
Dose
Every tank
after first tank
23-40 Litres
1 Caplet
½ Caplet
41-59 Litres
Caplet
1 Caplet
60-85 Litres
2 Caplet
Caplet
86-108 Litres
Caplet
2 Caplet
109-130 Litres
3 Caplet
Caplet
131-159 Litres
Caplet
3 Caplet
no drive
yahu bunun türkcesi yokmu arkadaşım
ALINTI
S. MPG-CAP™ nedir?
C. MPG-CAP™, motorunuzun yanma odasında mikroince bir kaplama yaratarak yakıtınızın daha etkili bir şekilde yanmasını sağlayarak, yakıt tasarrufu ve motorda güç artışını eşzamanlı olarak iyileştiren %100 organik bir motor bakım ürünüdür.
S: MPG-CAP™ etkili bir şekilde test edildi mi?
C: Evet, MPG-CAP™, etkili performans konusunda gerek laboratuvar gerekse yol testlerinde önemli sonuçlarla ölçülmüştür. Fuel Freedom International %7-14’lük yakıt tasarrufunu garanti eder. Çok hızlı araç kullanıyorsanız araç performansında artış göreceksiniz ancak yakıt tasarrufunda yüksek bir artış görmeyeceksiniz.
S. Neden MPG-CAP™ kullanmalıyım?
C. MPG-CAP™, galon başına düşen mil mesafesinde yakıt verimindeki artış, motor yıpranması ve dağılmada azalma, ayrıca motor çalışma sıcaklıklarında düşüş de dahil olmak üzere aracın genel performansını artırır.
S. MPG-CAP motorumun contasına zarar verir mi?
C. Hayır, MPG-CAP™, motora, contaya ya da kapaklara zararlı herhangi bir şey içermez.
S. MPG-CAP™ diğer katkı maddelerinden nasıl ayrılır?
C. MPG-CAP™ bir yakıt katkı maddesi değildir. O, motorun yanma odasındaki yanma sürecini iyileştirerek size daha düşük emisyonlar, aynı yakıtla daha fazla yol yapma imkanı ve daha iyi yakıt tasarrufu sağlayan bir yanma odası bakım ürünüdür. Bazı yakıt katkı maddeleri, temizleyici maddeler, ya da motorunuzun bozulmasına neden olabilecek zararlı kimyasal maddeler eklemek suretiyle yalnızca "yakıt sistem temizleyicileri" olarak hizmet eder. MPG-CAP™, çevre ve motorunuz için %100 güvenlidir.
S. MPG-CAP™ ile birlikte ne tür bir yakıt kullanılmalıdır?
C. Herhangi türde Benzin, Dizel, Biyodizel ve Etanol-Benzin karışımı kullanılabilir. Yakıtın oktanı ne kadar düşükse gelişme de o kadar çok fark edilebilir olur.
S. MPG-CAP™’i ne sıklıkta kullanmalıyım?
C. MPG-CAP™ her dolumda kullanılmalıdır.
S. MPG-CAP™ Ç.K.A (Çevre Koruma Ajansı) kayıtlı mı?
C. Evet. Ç.K.A, FFI tarafından sağlanan üçüncü taraf araştırma raporunu incelemiştir ve sonuç olarak ürünü (#201 220 001) kaydetmiştir. ÇKA hiçbir ürünü onaylamaz, sertifika vermez, garanti etmez.
S. MPG-CAP™ diğer motorlu makinelerde de kullanılabilir mi?
C. Evet, MPG-CAP tekne, zirai teçhizat, ağır makineler vs. gibi tüm dizel ya da benzin ile çalışan motorların yanı sıra, dıştan takma motor, zincir testere, çim biçme makinesi gibi 2-devirli araçlarda da kullanılabilir. Ayrıca, MPG-CAP™, biyodizel ve etanol-benzin karışımlarında da kullanılabilmektedir.
S. MPG-CAP™, yakıt emisyonlarını azaltarak çevreyi iyileştirebilir mi?
C. MPG-CAP™, karbon monoksit, hidrokarbonlar ve nitrojen oksidi azaltabilir.
S. Eğer MPG-CAP™’i elime dökersem ne olur?
C. Elinizdeki MPG-CAP™’i sadece temiz bir kâğıt havluyla silip kurutun ve ellerinizi yıkayın.
S. MPG-CAP™, antika veya klasik arabamda çalışır mı?
C. Evet. MPG-CAP™, eski arabaların performansını da geliştirir.
S. MPG-CAP arabamın yakıt sistemine ya da katalitik dönüştürücüye zarar verebilir mi?
C. MPG-CAP™, yakıt sistemlerine ya da katalitik dönüştürücülere zarar vermez.
S. MPG-CAP aşırı sıcaklarda arabamı çalıştırmaya yardımcı olur mu?
C. Evet. MPG-CAP hem sıcak hem de soğuk havalarda motorunuzu çalıştırmaya yardımcı olur.
S. MPG-CAP™, yakıt sistemimi diğer katkı maddelerinin yapabileceği gibi temizleyebilir mi?
C. MPG-CAP™ bir yakıt katkı maddesi değildir. Motorunuzun yanma odasında mikroince tabaka oluştururarak yakıtınızın daha verimli bir şekilde yanmasını sağlar.
S. MPG-CAP aynı yakıtla gittiğim mesafeyi arttırır mı?
C. MPC-CAP aracınızda önemli performans artışı ve verimlilik sağlayarak, tasarruf etmenize yardımcı olur. MPG-CAP motorunuza yaptığı bakımla motorunuzun ömrünü de uzatır. Çok hızlı araç kullanıyorsanız araç performansında artış göreceksiniz ancak yakıt tasarrufunda yüksek bir artış görmeyeceksiniz. Eğer hız limitleri dahilinde sürüyorsanız, aynı miktar yakıtla %7-14 daha fazla yol katedeceksiniz.
S.MPG-CAP çevre açısından güvenli mi?
C.MPG-CAP, ÇKA’na ( Çevre Koruma Ajansı) kayıtlıdır ve her türlü yakıtla kullanılması güvenlidir.
Bence kesinlikle denemeyin bile; tablet olarak kullanılıyor ve depoya atılıyor.. yakıt sistemine zarar verebilir.
Yakuz yazmış türkçesini teşekkürler.Amerikada çok yaygın kullanılıyormuş.hatta nasa da bunu kullanmaya başlamış.Türkiyede de yaygınlaşıyormuş.bir arkadaşım kullanıyor istanbulda %30 tasarruf ediyorum dedi.ama bir zararı olurmu bilmiyorum.
ben denemem memnunum hayatımdan paylaşım için teşekkürler.
